Hi All,
I’m using an argon to call a webhook and go straight back to deep sleep using
SystemSleepConfiguration config;
config.mode(SystemSleepMode::HIBERNATE)
.gpio(WKP, RISING);
System.sleep(config);
All of the code is in void setup, I do have some cloud functions that aren’t actively being used(I’m unsure if this affects whether it sleeps or not), and I’m using just the reset button to re-activate it as needed.
The documentation states that:
Typical power consumption in hibernate sleep mode, based on the wakeup source:
| Device | GPIO | RTC |
| T523 Eval | 103 uA | 95 uA |
| T402 Eval | 103 uA | 95 uA |
| Boron 2G/3G | 146 uA | n/a |
| Boron LTE | 106 uA | n/a |
| B402 SoM | 26 uA | n/a |
| B523 SoM | 30 uA | n/a |
| Argon | 65 uA | n/a |
| Electron | 114 uA | 114 uA |
| Photon | 114 uA | 114 uA |
So the argon should be using around 65uA in deep sleep, but I’ve tried both 3.7 Lipo 400mah and 500mah batteries respectively and they’re not lasting longer than a day in deep sleep mode.
When it runs the webhook the Argon is active for about 5 seconds total before going back to sleep and it’s only being run once a day.
Power consumption just isn’t adding up.
Is there some trick I’m missing with the deep sleep mode? Is there other components on the argon that need to be manually disabled prior to deep sleep?
Ben
