Welcome:
I’ve worked on a program to receive the data from the Arduino board to another Arduino board via serial to serial
Then the other Arduino linked me to the ethrnet board to send data to Google sheet.
When a connection TX and RX, I receives data in serial monitor but does not send anything to google sheet.
please help me`
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //Setting MAC Address
char server[] = "api.pushingbox.com"; //pushingbox API server
IPAddress ip(192,168,1,7); //Arduino IP address. Only used when DHCP is turned off.
EthernetClient client; //define 'client' as object
String data; //GET query with data
String suhu; //suhu (bahasa Indonesia) means temperature
boolean koneksi = false;
Serial.begin(115200);
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
Ethernet.begin(mac, ip);
delay(1000);
void loop(){
if (Serial.available() > 0) {
suhu = Serial.readString();
}// ADC to celcius conversion
kemasData(); //packing GET query with data
Serial.println("connecting...");
if (client.connect(server, 80)) {
sendData();
koneksi = true; //connected = true
else{
Serial.println("connection failed");
// loop
while(koneksi){
if (client.available()) {
char c = client.read(); //save http header to c
Serial.print(c); //print http header to serial monitor
if (!client.connected()) {
Serial.println();
Serial.println("disconnecting.");
Serial.print("Temperature Sent :");
Serial.println(suhu); //print sent value to serial monitor
client.stop();
koneksi = false;
data = ""; //data reset
delay(5000); // interval
void kemasData(){
data+="";
data+="GET /pushingbox?devid=vB990F945F7F0481&tempData="; //GET request query to pushingbox API
data+=suhu;
data+=" HTTP/1.1";
void sendData(){
Serial.println("connected");
client.println(data);
client.println("Host: api.pushingbox.com");
client.println("Connection: close");
client.println();
