I am trying to convert an Arduino sketch to run on a Photon but I am getting strange errors. The errors are below.
could not convert '_fetch_usbserial()' from 'USBSerial' to 'HardwareSerial& {aka USARTSerial&}'
The class is being instantiated using the following statement:
Leddar16 Leddar1(115200,1);
//Initialize Leddar
Leddar1.init();
Here is the .h file. I would appreciate any help to determine the cause.
#ifndef Leddar_h
#define Leddar_h
/* _____STANDARD INCLUDES____________________________________________________ */
#include "Arduino.h"
/* _____PROJECT INCLUDES_____________________________________________________ */
/* _____LIBRARY DEFINITIONS__________________________________________________ */
#define DEFAULT_BAUD_RATE 115200
// Default address for the slave
#define DEFAULT_ADDRESS 0x01
//Error codes
#define ERR_LEDDAR_BAD_CRC -1
#define ERR_LEDDAR_NO_RESPONSE -2
#define ERR_LEDDAR_BAD_RESPONSE -3
#define ERR_LEDDAR_SHORT_RESPONSE -4
#define ERR_LEDDAR_SERIAL_PORT -5
// Number of detections does not match
#define ERR_LEDDAR_NB_DETECTIONS -6;
/// Represents a measurement:
struct Detection
unsigned char Segment;
unsigned int Distance;
unsigned int Amplitude;
// Default constructor
Detection() : Segment(0), Distance(0xFFFF), Amplitude(0) { }
class Leddar16
public:
Leddar16()
: BaudRate(DEFAULT_BAUD_RATE), SlaveAddress(DEFAULT_ADDRESS), NbDet(0), TxEn_Pin(0), TxEn_Action(0), SerialPort(Serial)
Leddar16( unsigned long Baud, unsigned char Addr = DEFAULT_ADDRESS, HardwareSerial& Port = Serial, unsigned char Pin = 0, unsigned char Action = 0)
: BaudRate(Baud), SlaveAddress(Addr), NbDet(0), TxEn_Pin(Pin), TxEn_Action(Action) , SerialPort(Port)
Leddar16( unsigned long Baud, unsigned char Addr, unsigned char Pin , unsigned char Action )
: BaudRate(Baud), SlaveAddress(Addr), NbDet(0), TxEn_Pin(Pin), TxEn_Action(Action) , SerialPort(Serial)
void init();
char getDetections();
char sendRequest();
char parseResponse();
void clearDetections();
public:
unsigned char NbDet;
Detection Detections[50];
unsigned long TimeStamp;
unsigned char LEDPower;
unsigned char Status;
private:
unsigned long BaudRate;
unsigned char SlaveAddress;
unsigned char TxEn_Pin;
unsigned char TxEn_Action;
HardwareSerial& SerialPort;
#endif
