Is there any way to adjust the the transmit power for the Wifi transceiver? I have an application that requires the transmitter to operate at or below 10 mW EIRP. I found a reference to a setting something in a custom nvram file, but I haven’t found how that’s done.
@openflight, not directly in the Particle firmware. However, you may be able to do so if you dig through the WICED code and do a custom build of the firmware (ie not pretty!). I do recall a discussion on a lower power WiFi mode but can’t recall the topic that was discussed in. Perhaps @rickkas7 can recall.
