Hello Community,
I am excited to share with you that we have just released Varia, a retrofit mounting system for the Tracker One. While we know that Tracker One greatly reduces the complexities of getting started with asset tracking projects, the fact that it's not easily mounted to anything has always been challenging.
With Varia, we hope to provide a mounting solution to securely fix the Tracker One to any asset. The repo contains all the necessary files to print or manufacture your own brackets, as well as a BOM for the additional hardware components required. This is an open-source project, so we encourage you to modify and improve it as you see fit!
