I am starting an android app project using Particle Android SDK, but every time I run the simple app in the emulator that initializes the SDK using
ParticleCloudSDK.init(this); in onCreate method, I get this error.
java.lang.BootstrapMethodError: Exception from call site #5 bootstrap method
at io.particle.android.sdk.cloud.ApiFactory.buildNewCloudApi(ApiFactory.java:75)
at io.particle.android.sdk.cloud.SDKProvider.(SDKProvider.java:48)
at io.particle.android.sdk.cloud.ParticleCloudSDK.initWithParams(ParticleCloudSDK.java:47)
at io.particle.android.sdk.cloud.ParticleCloudSDK.init(ParticleCloudSDK.java:24)
at com.example.putra.myapplication.MainActivity.onCreate(MainActivity.java:16)
at android.app.Activity.performCreate(Activity.java:7136)
at android.app.Activity.performCreate(Activity.java:7127)
at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1271)
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2893)
at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:3048)
at android.app.servertransaction.LaunchActivityItem.execute(LaunchActivityItem.java:78)
at android.app.servertransaction.TransactionExecutor.executeCallbacks(TransactionExecutor.java:108)
at android.app.servertransaction.TransactionExecutor.execute(TransactionExecutor.java:68)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1808)
at android.os.Handler.dispatchMessage(Handler.java:106)
at android.os.Looper.loop(Looper.java:193)
at android.app.ActivityThread.main(ActivityThread.java:6669)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:858)
Caused by: java.lang.ClassCastException: Bootstrap method returned null
This is my build.gradle app module
apply plugin: 'com.android.application'
android {
compileSdkVersion 28
defaultConfig {
applicationId "com.example.putra.myapplication"
minSdkVersion 26
targetSdkVersion 28
multiDexEnabled true
versionCode 1
versionName "1.0"
testInstrumentationRunner "android.support.test.runner.AndroidJUnitRunner"
buildTypes {
release {
minifyEnabled false
proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.pro'
dependencies {
implementation 'io.particle:devicesetup:0.5.3'
implementation 'io.particle:cloudsdk:0.5.0'
implementation fileTree(dir: 'libs', include: ['*.jar'])
implementation 'com.android.support:appcompat-v7:28.0.0-alpha3'
implementation 'com.android.support.constraint:constraint-layout:1.1.2'
testImplementation 'junit:junit:4.12'
androidTestImplementation 'com.android.support.test:runner:1.0.2'
androidTestImplementation 'com.android.support.test.espresso:espresso-core:3.0.2'
implementation 'com.android.support:recyclerview-v7:28.0.0-alpha3'
implementation 'com.android.support:multidex:1.0.3'
My friend who works on the same project also has the same issue in initializing Particle Android SDK, some help will be very appreciated.
