I have made a few apps using the particle SDK and i had little to no issues. I am currently working to make a Particle plugin for Flutter. If you don’t know what flutter is, check it out, much like particle for IOT, flutter is a batteries included solution to mobile app development. When i am trying to make this plugin i am running into some errors that i have never seen before.
Error connecting to the service protocol: HttpException: Connection closed before full header was received, uri = http://127.0.0.1:60443/ws
and---------------------------------------------------------------
2018-12-11 10:01:30.854 11612-11612/positev.flutterpluginexample E/flutter: [ERROR:flutter/shell/platform/android/platform_view_android_jni.cc(40)] java.lang.BootstrapMethodError: Exception from call site #0 bootstrap method
at io.particle.android.sdk.cloud.ApiFactory.buildNewCloudApi(ApiFactory.java:75)
at io.particle.android.sdk.cloud.SDKProvider.(SDKProvider.java:48)
at io.particle.android.sdk.cloud.ParticleCloudSDK.initWithParams(ParticleCloudSDK.java:47)
at io.particle.android.sdk.cloud.ParticleCloudSDK.init(ParticleCloudSDK.java:24)
at positev.flutterplugin.FlutterPlugin.onMethodCall(FlutterPlugin.java:70)
at io.flutter.plugin.common.MethodChannel$IncomingMethodCallHandler.onMessage(MethodChannel.java:200)
at io.flutter.view.FlutterNativeView.handlePlatformMessage(FlutterNativeView.java:163)
at android.os.MessageQueue.nativePollOnce(Native Method)
at android.os.MessageQueue.next(MessageQueue.java:326)
at android.os.Looper.loop(Looper.java:160)
at android.app.ActivityThread.main(ActivityThread.java:6669)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:858)
Caused by: java.lang.ClassCastException: Bootstrap method returned null
So at first i thought it was because i was making a plugin which brings about some special circumstances but then i tried making a regular application like i did several times before and im still getting those errors. Java is set to version 8, the only access to the cloud i am requesting is the init. This is on a barebones flutter app where the dependency has just been established.
This is the MainActivity for android. User interface is brought one layer up with flutter so you wont see and UI code here.
package positev.testparticle;
import android.os.Bundle;
import io.flutter.app.FlutterActivity;
import io.flutter.plugins.GeneratedPluginRegistrant;
import io.particle.android.sdk.cloud.ParticleCloudSDK;
public class MainActivity extends FlutterActivity {
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
GeneratedPluginRegistrant.registerWith(this);
ParticleCloudSDK.init(this);
If youre familiar with flutter or dart, this is the main class where the user interface is built and ran. It is the sample applicaiton when the project is first built.
import 'package:flutter/material.dart';
void main() => runApp(MyApp());
class MyApp extends StatelessWidget {
// This widget is the root of your application.
@override
Widget build(BuildContext context) {
return MaterialApp(
title: 'Flutter Demo',
theme: ThemeData(
// This is the theme of your application.
// Try running your application with "flutter run". You'll see the
// application has a blue toolbar. Then, without quitting the app, try
// changing the primarySwatch below to Colors.green and then invoke
// "hot reload" (press "r" in the console where you ran "flutter run",
// or simply save your changes to "hot reload" in a Flutter IDE).
// Notice that the counter didn't reset back to zero; the application
// is not restarted.
primarySwatch: Colors.blue,
home: MyHomePage(title: 'Flutter Demo Home Page'),
class MyHomePage extends StatefulWidget {
MyHomePage({Key key, this.title}) : super(key: key);
// This widget is the home page of your application. It is stateful, meaning
// that it has a State object (defined below) that contains fields that affect
// how it looks.
// This class is the configuration for the state. It holds the values (in this
// case the title) provided by the parent (in this case the App widget) and
// used by the build method of the State. Fields in a Widget subclass are
// always marked "final".
final String title;
@override
_MyHomePageState createState() => _MyHomePageState();
class _MyHomePageState extends State<MyHomePage> {
int _counter = 0;
void _incrementCounter() {
setState(() {
// This call to setState tells the Flutter framework that something has
// changed in this State, which causes it to rerun the build method below
// so that the display can reflect the updated values. If we changed
// _counter without calling setState(), then the build method would not be
// called again, and so nothing would appear to happen.
_counter++;
@override
// This method is rerun every time setState is called, for instance as done
// by the _incrementCounter method above.
// The Flutter framework has been optimized to make rerunning build methods
// fast, so that you can just rebuild anything that needs updating rather
// than having to individually change instances of widgets.
return Scaffold(
appBar: AppBar(
// Here we take the value from the MyHomePage object that was created by
// the App.build method, and use it to set our appbar title.
title: Text(widget.title),
body: Center(
// Center is a layout widget. It takes a single child and positions it
// in the middle of the parent.
child: Column(
// Column is also layout widget. It takes a list of children and
// arranges them vertically. By default, it sizes itself to fit its
// children horizontally, and tries to be as tall as its parent.
// Invoke "debug painting" (press "p" in the console, choose the
// "Toggle Debug Paint" action from the Flutter Inspector in Android
// Studio, or the "Toggle Debug Paint" command in Visual Studio Code)
// to see the wireframe for each widget.
// Column has various properties to control how it sizes itself and
// how it positions its children. Here we use mainAxisAlignment to
// center the children vertically; the main axis here is the vertical
// axis because Columns are vertical (the cross axis would be
// horizontal).
mainAxisAlignment: MainAxisAlignment.center,
children: <Widget>[
Text(
'You have pushed the button this many times:',
Text(
'$_counter',
style: Theme.of(context).textTheme.display1,
floatingActionButton: FloatingActionButton(
onPressed: _incrementCounter,
tooltip: 'Increment',
child: Icon(Icons.add),
), // This trailing comma makes auto-formatting nicer for build methods.
Both errors lead to immediate crash before any user interface shows every time the software is loaded to the emulator. The emulator is a google pixel 2 running Android 9.0 API 28, 3.2 GB Ram, x86 cpu
I hope i have provided enough detail to lead to a solution. Thank you for any help!
