Altitude from ASSETTRACKERRK
Playing around with this library i got good results on a google map - but i like to show more Data from the GPS like altitude, speed or hdop - but perhaps im to stupid to figure out how i can access this values from the ASSETTRACKERRK lib. Someone knows?
I’m pretty sure the FGPMMOPA6H GPS module doesn’t support altitude. Even if it did, GPS-based altitude is not at all accurate; it’s not uncommon to get altitude errors of 40 meters or more on inexpensive GPS hardware that does support it.
I am using a electron with a BeeGPs and I am pretty sure there is some aditional data coming in from the gps. With Assettracker i was able to get the hdop to show how accurate the lat lon is. This is not possible with assettrackerrk… if i get a altitude which is 40m inaccurate i m fine because here in switzerland i deal with altitudes between 4000m and 300m - 40m dosnt matter…
I stand corrected. It does return the altitude, it just wasn’t in the old AssetTracker library.
If you’re using the backward compatibility layer, you’d use something like:
tracker.getTinyGPSPlus()->altitude.meters();
Basically, altitude is a member of the TinyGPS++ object, and there are accessors for altitude for meters, feet, etc…
Ahhh -YES that works and is very accurate!
Thank you very much!
