Installed the new A5 build and got the following local compilation error on a totally new project (no code) for a Xenon on 0.8.0-rc.25. Workspace settings and environment audit below.
> Executing task in folder HelloWorld: make -f 'C:\Users\Joey Gennari\.particle\toolchains\buildscripts\1.0.1\Makefile' compile-user <
cd "C:/Users/Joey Gennari/.particle/toolchains/deviceOS/0.8.0-rc.25/firmware-0.8.0-rc.25/main" && make all
make[1]: Entering directory '/cygdrive/c/Users/Joey Gennari/.particle/toolchains/deviceOS/0.8.0-rc.25/firmware-0.8.0-rc.25/main'
make -C ../modules/xenon/user-part all
make[2]: Entering directory '/cygdrive/c/Users/Joey Gennari/.particle/toolchains/deviceOS/0.8.0-rc.25/firmware-0.8.0-rc.25/modules/xenon/user-part'
make[2]: *** /cygdrive/c/Users: Is a directory. Stop.
make[2]: Leaving directory '/cygdrive/c/Users/Joey Gennari/.particle/toolchains/deviceOS/0.8.0-rc.25/firmware-0.8.0-rc.25/modules/xenon/user-part'
make[1]: *** [../build/recurse.mk:12: modules/xenon/user-part] Error 2
make[1]: Leaving directory '/cygdrive/c/Users/Joey Gennari/.particle/toolchains/deviceOS/0.8.0-rc.25/firmware-0.8.0-rc.25/main'
make: *** [C:\Users\Joey Gennari\.particle\toolchains\buildscripts\1.0.1\Makefile:35: compile-user] Error 2
The terminal process terminated with exit code: 2
Press any key to close the terminal.
*** WARNING: MAY CONTAIN CONFIDENTIAL INFORMATION - PLEASE SANITIZE BEFORE SHARING ***
To report an issue, visit:
https://community.particle.io/t/information-how-to-report-bugs-and-provide-feedback/44245
"username": "jgennari@gmail.com",
"workspace": {
"name": "HelloWorld (Workspace)",
"isWorkspace": true,
"configFile": "HelloWorld.code-workspace",
"root": "c:\\Users\\Joey Gennari\\Desktop\\Particle\\HelloWorld",
"files": [
".vscode",
".vscode\\launch.json",
".vscode\\settings.json",
"project.properties",
"README.md",
"src",
"src\\HelloWorld.ino",
"xenon_firmware_1544094062586.bin"
"vscode": {
"appName": "Visual Studio Code",
"appRoot": "c:\\Users\\Joey Gennari\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
"machineId": "d60e1ad51182be8a7f322f3a29b5cccc577eb3dc402c12ef6c7b1a2715780f45",
"sessionId": "1159a670-cc4d-4ded-bc33-8db83c6c89141544093496338",
"version": "1.29.1"
"cli": {
"binpath": "C:\\Users\\Joey Gennari\\.vscode\\extensions\\particle.particle-vscode-core-1.0.0-alpha.5\\src\\cli\\bin\\windows\\amd64\\particle.exe",
"ok": true,
"version": "1.35.2"
"localCompiler": {
"dependencies": [
"deviceOS@0.8.0-rc.25",
"gcc-arm@5.3.1",
"buildtools@1.0.1",
"buildscripts@1.0.1",
"deviceOS@0.7.0",
"buildscripts@1.0.0"
"platform": {
"os": "windows",
"type": "Windows_NT",
"release": "10.0.17134",
"arch": "x64",
"path": {
"key": "Path",
"value": "C:\\ProgramData\\DockerDesktop\\version-bin;C:\\Program Files\\Docker\\Docker\\Resources\\bin;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\ProgramData\\Oracle\\Java\\javapath;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\Program Files (x86)\\Windows Kits\\10\\Windows Performance Toolkit\\;C:\\Program Files\\Microsoft SQL Server\\130\\Tools\\Binn\\;C:\\Program Files\\dotnet\\;C:\\Program Files\\Git\\cmd;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\nodejs\\;C:\\Users\\Joey Gennari\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Bin;C:\\Users\\Joey Gennari\\AppData\\Local\\particledev\\bin;C:\\Users\\Joey Gennari\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\Joey Gennari\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Users\\Joey Gennari\\AppData\\Roaming\\npm"
"homeDir": "C:\\Users\\Joey Gennari",
"particleDir": "C:\\Users\\Joey Gennari\\.particle",
"localCompilerToolchainDir": "C:\\Users\\Joey Gennari\\.particle\\toolchains"
"env": {
"ADSK_CLM_WPAD_PROXY_CHECK": "FALSE",
"ALLUSERSPROFILE": "C:\\ProgramData",
"AMD_ENTRYPOINT": "vs/workbench/node/extensionHostProcess",
"APPDATA": "C:\\Users\\Joey Gennari\\AppData\\Roaming",
"APPLICATION_INSIGHTS_NO_DIAGNOSTIC_CHANNEL": "true",
"CARBON_MEM_DISABLE": "1",
"CommonProgramFiles": "C:\\Program Files\\Common Files",
"CommonProgramFiles(x86)": "C:\\Program Files (x86)\\Common Files",
"CommonProgramW6432": "C:\\Program Files\\Common Files",
"COMPUTERNAME": "DESKTOP-QNDVA34",
"ComSpec": "C:\\WINDOWS\\system32\\cmd.exe",
"DriverData": "C:\\Windows\\System32\\Drivers\\DriverData",
"ELECTRON_RUN_AS_NODE": "1",
"FPS_BROWSER_APP_PROFILE_STRING": "Internet Explorer",
"FPS_BROWSER_USER_PROFILE_STRING": "Default",
"FSHARPINSTALLDIR": "C:\\Program Files (x86)\\Microsoft SDKs\\F#\\4.1\\Framework\\v4.0\\",
"GOOGLE_API_KEY": "AIzaSyAQfxPJiounkhOjODEO5ZieffeBv6yft2Q",
"HOMEDRIVE": "C:",
"HOMEPATH": "\\Users\\Joey Gennari",
"LOCALAPPDATA": "C:\\Users\\Joey Gennari\\AppData\\Local",
"LOGONSERVER": "\\\\DESKTOP-QNDVA34",
"NUMBER_OF_PROCESSORS": "4",
"OneDrive": "C:\\Users\\Joey Gennari\\OneDrive",
"OS": "Windows_NT",
"Path": "C:\\ProgramData\\DockerDesktop\\version-bin;C:\\Program Files\\Docker\\Docker\\Resources\\bin;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\ProgramData\\Oracle\\Java\\javapath;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\Program Files (x86)\\Windows Kits\\10\\Windows Performance Toolkit\\;C:\\Program Files\\Microsoft SQL Server\\130\\Tools\\Binn\\;C:\\Program Files\\dotnet\\;C:\\Program Files\\Git\\cmd;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\nodejs\\;C:\\Users\\Joey Gennari\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Bin;C:\\Users\\Joey Gennari\\AppData\\Local\\particledev\\bin;C:\\Users\\Joey Gennari\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\Joey Gennari\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Users\\Joey Gennari\\AppData\\Roaming\\npm",
"PATHEXT": ".COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC",
"PIPE_LOGGING": "true",
"PROCESSOR_ARCHITECTURE": "AMD64",
"PROCESSOR_IDENTIFIER": "Intel64 Family 6 Model 60 Stepping 3, GenuineIntel",
"PROCESSOR_LEVEL": "6",
"PROCESSOR_REVISION": "3c03",
"ProgramData": "C:\\ProgramData",
"ProgramFiles": "C:\\Program Files",
"ProgramFiles(x86)": "C:\\Program Files (x86)",
"ProgramW6432": "C:\\Program Files",
"PSModulePath": "%ProgramFiles%\\WindowsPowerShell\\Modules;C:\\WINDOWS\\system32\\WindowsPowerShell\\v1.0\\Modules;C:\\Program Files\\WindowsPowerShell\\Modules\\;C:\\Program Files (x86)\\Microsoft SDKs\\Azure\\PowerShell\\ResourceManager\\AzureResourceManager\\;C:\\Program Files (x86)\\Microsoft SDKs\\Azure\\PowerShell\\ServiceManagement\\;C:\\Program Files (x86)\\Microsoft SDKs\\Azure\\PowerShell\\Storage\\",
"PUBLIC": "C:\\Users\\Public",
"SystemDrive": "C:",
"SystemRoot": "C:\\WINDOWS",
"TEMP": "C:\\Users\\JOEYGE~1\\AppData\\Local\\Temp",
"TMP": "C:\\Users\\JOEYGE~1\\AppData\\Local\\Temp",
"USERDOMAIN": "DESKTOP-QNDVA34",
"USERDOMAIN_ROAMINGPROFILE": "DESKTOP-QNDVA34",
"USERNAME": "Joey Gennari",
"USERPROFILE": "C:\\Users\\Joey Gennari",
"VBOX_MSI_INSTALL_PATH": "C:\\Program Files\\Oracle\\VirtualBox\\",
"VERBOSE_LOGGING": "true",
"VSCODE_CWD": "C:\\Users\\Joey Gennari\\AppData\\Local\\Programs\\Microsoft VS Code",
"VSCODE_HANDLES_UNCAUGHT_ERRORS": "true",
"VSCODE_IPC_HOOK": "\\\\.\\pipe\\89f2ea19683bad38e2e151de6b81cc5f-1.29.1-main-sock",
"VSCODE_IPC_HOOK_EXTHOST": "\\\\.\\pipe\\vscode-ipc-8fee111f-9ebd-40f8-946a-ec84dcf5c7fe-sock",
"VSCODE_LOGS": "C:\\Users\\Joey Gennari\\AppData\\Roaming\\Code\\logs\\20181203T163737",
"VSCODE_LOG_LEVEL": "undefined",
"VSCODE_LOG_STACK": "undefined",
"VSCODE_NLS_CONFIG": "{\"locale\":\"en-us\",\"availableLanguages\":{},\"_languagePackSupport\":true}",
"VSCODE_NODE_CACHED_DATA_DIR": "C:\\Users\\Joey Gennari\\AppData\\Roaming\\Code\\CachedData\\bc24f98b5f70467bc689abf41cc5550ca637088e",
"VSCODE_PID": "1956",
"windir": "C:\\WINDOWS",
"WIX": "C:\\Program Files (x86)\\WiX Toolset v3.11\\"
"versions": {
"http_parser": "2.7.0",
"node": "8.9.3",
"v8": "6.1.534.41",
"uv": "1.15.0",
"zlib": "1.2.11",
"ares": "1.10.1-DEV",
"modules": "57",
"nghttp2": "1.25.0",
"openssl": "1.0.2n"
"extensions": [
"id": "ms-vscode.node-debug",
"version": "1.29.2"
"id": "ms-vscode.node-debug2",
"version": "1.29.5"
"id": "ms-vscode.references-view",
"version": "0.0.8"
"id": "marus25.cortex-debug",
"version": "0.1.21"
"id": "ms-vscode.cpptools",
"version": "0.20.1"
"id": "particle.particle-vscode-core",
"version": "1.0.0-alpha.5"
"id": "particle.particle-vscode-snippets",
"settings": {
"extensions.ignoreRecommendations": true,
"C_Cpp.default.configurationProvider": "particle.particle-vscode-core",
"files.associations": {
"*.ino": "cpp"
"particle.firmwareVersion": "0.8.0-rc.25",
"particle.targetPlatform": "xenon"
"folders": [
"path": "."
