After hard reset core flashing cyan [SOLVED]
I have two spark core, one is working.The other had to do a factory reset, then after that he was blinking blue, I put the ssid and password, after which it flashes cyan fast, which can be?
I made a:
spark flash --usb tinker
after 1 minute the core is connected, but after more or less 2 minutes, back to flashing fast cyan again. And this becomes a loop
problem solved after apply cc3000 patch
For others who have this issue, the solution on the core indeed is often the cc3000 patch. Install instructions available here.
thank you
