Adding libraries from github
I am trying to add these two libraries to use on the cloud ide.
Is there a guide on how to add ones not in the community? Search through documentation and forumn :confused:
thanks
https://docs.particle.io/guide/tools-and-features/libraries/#contributing-libraries
If itโ€™s just a single use case, you can click the little + icon in the top right and copy the files manually.
Adafruit_VL53L0X is already there
https://build.particle.io/libs/Adafruit_VL53L0X/0.0.4
