So I just purchased 2 particle photons, and as I was performing the set up for the first photo, I was running into a couple problems. Eventually I resolved them, and connected my Photon to Wifi. However, I was under the impression I typed something wrong in the password as the light was flashing green. Because of that, I pressed refresh as that was recommended. Unfortunately, a moment later, the Photon switched to a “Breathing Cyan”. I was unable to “Claim” my photon nor name it, and I can’t do anything with it in the CLI since my USB doesn’t detect it now.
What should I do? No commands in the CLI relating to “particle” do anything because it assumes I have nothing in my USB. I also can’t factory reset the Particle by holding Setup or Reset or combination of both. Please help! Thank you so much.
