I’m trying to run the Spark Cloud in Bluemix and after a bit of fiddling around it’s really starting…
Unfortunately I get the message
"code": 400,
"error": "invalid_request",
"error_description": "The access token was not found"
when a directly browse the url.
What initial steps do I have to do, to configure the cloud?
Install particle-cli and do a particle config xxxx.
See: https://github.com/spark/particle-cli#particle-config
followed by particle login
@kennethlimcp, Thanks. The config command is not documented in the particle CLI documentation in the particle.io page. Or may be I’m missing it. This should be considered worth adding for everyone’s benefit.
Good point. there’s also outdated stuff to be removed.
