Datacake has updated its integration scheme with Particle devices. The previously documented direct integration is no longer the recommended path. The platform now uses a generic webhook workflow. If you’re setting up a new Datacake integration with Particle (or revisiting an existing one), you can find the updated documentation here: Datacake | Integrations | Particle
