It seems we can sort of fix it by resetting the device, but when we do that both the short and long version of the code show up. E.g. for the photon in the screenshot we would see “Photon-B2UG4X” and “Photon-B2UG” show up.
If we try to connect to the long particle WiFi code the pairing process loops infinitely.
Anyone else experiencing this at all? I’ve checked a few boards and it’s happening on all of them
The 6-digit code has been introduced quite a while back - that’s the current default.
What device OS version are you running?
Are you using the most recent mobile app and/or mobile SDK?
Interesting to know. We’ve had to downgrade all of our devices to Particle version 6.3.0 because of incompatibilities in the firmware that we flash onto the device (7.0.0 ended up soft-bricking the devices).
So if we downgrade first then the WiFi codes should go back to 4 digits I assume?
