Can I power a 5 Volt segment display like this one
From the Vin Pin if powering the Photon with USB OR do I need to buy a 3.3 Volt LCD display?
Please if possible explain how it should be connected.
Thank you.
Thank you.
Yes you can power it from VIN.
https://docs.particle.io/datasheets/photon-datasheet/#power
To add to @JumpMaster's comment
You can power the display off Vin and the communication pins (D0 = SDA / D1 = SCL for I2C) are 5V tolerant.
https://docs.particle.io/datasheets/photon-datasheet/#peripherals-and-gpio
This should also answer your question of how to connect the thing to the Photon.
Photon -> LCD
Vin Vcc
GND GND
D0 SDA
D1 SCL
Depending on the board you might need to add some pull-up resistors to SDA and SCL (to Vcc) 4k7 or so.
