I am working on a prototype for a product and was hoping to use the Photon as the access point so phones and other devices could connect and send messages to the micro controller to control a DSP over SPI.
What is the max amount of connections for the Photon if it’s setup as an access point?
I’m also looking at implementing a websocket server (possibly using https://github.com/Na2l/spark-websocket-server) as well and at times would like to send DSP values via SPI back to the connected device in real-time via a websocket. An example would be volume level from an audio signal sent every 100 ms for multiple clients.
Is the throughput good enough with the Photon to have this kind of real-time data pumping through it?
