Yet another wifi-enabled thermostat
hi all,
i like to be able to remote control (over internet) my siemens thermostat. i like to keep the solution very light. my thermostat has a button to switch between different modes (there is a “continuous comfort mode” set to 21C and a “savings mode” set to 17C)…so i like to hookup the core to be able to set the mode remotely…that’s basically it i am not interested in reading out sensor values and/or adjusting temperature. just pushing the button so to say :wink:
do you guys think this is possible? what do i need more besides the core???
the thermostat i am talking about is the following:
http://www.buildingtechnologies.siemens.com/bt/global/en/products/HVAC-Products/Thermostats/Autonomous-room-thermostats/Pages/REV24.aspx
i hope people can give me some guidance
https://hit.sbt.siemens.com/HIT/modules/kernel/UI/GetBinData.aspx?RC=HQEU&LANG=en&VALUE=Assets%2FA6V10207245.jpg
brgds gj
Probably a simple relay to get going?
You just need to tap on the mechanical switch legs and connected to a relay to short them together.
This requires a little soldering and tearing the Thermostat up though…
hi kenneth & the spark community
thanks for your quick reply…i am unfortunately not an expert…but i did see some further pointers in the manual…apparently it has already some wiring provision for the remote…so thats nice i think…plz see below:
so what do u think? its possible right? do i need to order the full kit or only the core?
brgds gertjan
@gjeee, what i can suggest you do is to use a wire and short T1 & T2 together and see if the ‘Temp Telephone’ icon appears on your screen.
Loosen the terminal blocks and jump a wire between the 2 terminals and tighten the scews then slide back the Thermostat
PLEASE be careful with this due to the high voltage present just on the right!!
Let’s verify it works 1st :slight_smile:
hi,
thanks. so i need the core + some wiring + relay
is this relay suitable http://nl.mouser.com/ProductDetail/Panasonic-Electric-Works/JS1-5V-F/?qs=UO/x91QLkSBQtQiRxAfeSw==
how about powering the core? how should i go about that?
brgds gj
okay i will check this first....thanks!
@gjeee Are you able to trigger it using a wire and get your desired output?
  1. A latching relay or the relay you chosen depending on requirement
so you don’t waste power continuously powering the relay to activate the Remote control, unless you need a fail-safe whereby should the Spark core fail, the Remote control get turned off.
http://nl.mouser.com/ProductDetail/KEMET-NEC-TOKIN/EE2-5TNU-L/?qs=sGAEpiMZZMul3u5M2kZC5MPMcRZzPawB
  1. A USB Powerbank to power up the Core via USB-cable OR a USB-adapter (so not cool being wired :stuck_out_tongue:)
hi
i am not at home so didn’t try out yet will let u know asap…but just out of curiosity…how long would a powerbank last to power this core? is there also a possibility with just regular batteries??? otherwise i just use an USB-adapter hooked to main circuit.
@gjeee I remember reading somewhere the current usage should be in the range of 100-300 mA with the wifi transmission going.
@zachary where’s the current readings? Can’t remember where i read it
Regular batteries are not so ideal if you are running it 24/7. It’s possible if we can put the :spark: core to sleep which uses less power but their some bug with the sleep() as of know. BUT do KIV this point.
You will definitely benefit from having the low power mode once the bug is fixed! :smile:
The USB adapter would be your good friend for the moment
Electrical characteristics of the Core are described here:
http://docs.spark.io/#/hardware/spark-core-datasheet-electrical-characteristics
:spark: Core sleep modes for using less power are described here:
http://docs.spark.io/#/firmware/cloud-functions-sleep
Cheers!
hi zachary, kenneth,
suppose i put the device in a cycle of deep sleeping 59s and 1s active, would it still be possible for my remote app to send a signal which core picks ups once it awakes ???
that way i can reduce power consumption drastic.
brgds gertjan
You can definitely put the Core to sleep, and perform communication when it wakes up. However, messages sent from the remote app to the Core while the Core is asleep will currently time out. So, you can handle this a few different ways, whichever you prefer:
  • The remote app can be made so that it is ok for the Core to receive some messages and not others. That way the remote app can simply keep functioning (with some requests to the Core failing) and your Core can go to sleep after it receives a message from the remote app.
  • The Core can use UDP or TCPClient to contact your remote app immediately upon wake up. The remote app can wait for this connection before it performs other work with the Core.
  • Once we finish Spark.publish() your remote app can subscribe to an event the Core publishes when it wakes up. When it receives the event it can perform other communication with the Core.
Also, I forgot to mention—the Core can take somewhere between 1 second and about 15 seconds to connect to Wi-Fi and the :spark: Cloud. So keep in mind that the Core will have to remain awake for that long at least. Plus, if you want to flash new code to your Core, it has to stay awake long enough to finish the update.
hi and thanks again for your replies. one more question :wink:
suppose i have some nice spark app powered by some power pack (where wifi is always on)..in the docs i have read
Ideal sources of power can be: 3.6V LiPo battery, 4AA battery pack, backup USB battery or an USB wall charger.
i checked these lipo batteries...most of these have a capacity of lets say 1000mAh and lets assume the core will consume 100mA
does that mean that this particular spark app would last 1000/100=10 hrs?????
thats not that much or am i wrong here????
You’re right with the calculations.
Having a wifi chip does take up some decent power.
Your math is correct, but you must consider the duty cycle of the Core. It might draw 100-300mA for a short duration, averaged over the time it is asleep drawing a couple hundred microamps. So in theory you can extend your battery life greatly by lowering the duty cycle of awake time vs. sleep time. Especially if you don’t need to respond that fast.
Also if you can power your Core with regulated 3.3V directly on the 3V3 pin, when your Core sleeps, the LDO won’t even consume 100 - 200uA anymore.
More info here: https://community.spark.io/t/findings-sleep-modes/2471
hi
thanks for the background info…integrating the core/relay directly with my thermostat is not ideal because there is no electrical plug closeby and i don’t like a 4 m wire (and a powerpack is not an option i guess because of the limited lifetime)
so i thought a bit more and came up with an alternative solution:
  • i will use a radio-controlled relay between T1 and T2 (see picture above)
  • the core will function as a wifi-enabled base-station powered by main grid. if this base-sation will get a signal of my sparkapp over internet it will switch the relay in my thermostat via a radio-signal
Questions:
1 can the spark core control the relay with a radio signal???
2 do you have any suggestion for a radio-controlled relay…i saw this one: http://www.robotshop.com/en/dimension-engineering-battle-switch.html - is that a good suggestion?
I think it's going to get complicated (Rube Goldberg style) rather quickly to put a RC radio link in-between the Spark Core and your Thermostat, but I don't see an easy way to get power from your 24-250VAC terminals... you could energy harvest power from those, but if you draw too much power it will turn on your blower relay. I would like to offer a solution that doesn't make you create a "one-off" system based on your specific HVAC unit.
I understand how you are putting it in Remote mode, but are there terminals on the back to interface to the other buttons as well? What are those requirements?
I think what you need is a low power receiver/control unit that can be powered from the (2) AA batteries in the Thermostat that can sleep from time to time to conserve power. Check out this thread for some nice radios that would do the trick: [Request - Answered] nRF24L01+ library - Libraries - Particle You just need a 3.3V Arduino Pro Mini on the thermostat side... running at 8MHz. Probably using small Solid State Relays for the momentary type stuff, and/or small signal Latching relays for things that need to be connected for a bit (like the Remote terminals).
you are right BDub! let me look into your suggestions and digest a bit...
thanks!!!!
yes i managed to do that....i closed that circuit and the remote icon started to blink....
STATUS:
ESTIMATION OPERATIONAL TIME:
  • capacity of 4x3500=14000 mAh
  • 15 minutes duty cycle....
  • awakening from deep sleep to wifi-connected state will take on average 8 sec
  • when awake it will draw (50+300)/2=175 mA on average
--> operational time: 14000/(8x(50+300)/2) x 15 x 60 =9000 hrs ~ 1YR
are my assumptions/calculations correct?
i'll keep u posted of further progress.
GJ
