Hello,
This is my first request for help in this community, i’m hopping i’m on the right place.
It’s quite related to this topic explaining how to use the DfPlayer-Mini (mp3 player) with the Photon board.
I need to use it with a Xenon. I know, board not supported anymore, but i have plenty of them and i need bluetooth. I’m using it off the cloud anyways.
It basically works fine, i used the VUSB pin to power the player and power it from a wall outlet to be sure to have enough power.
My problem is that the mp3 board’s Init() does not completes until i unplug the VUSB pin and re plug it.
In other words :
Serial1.begin(9600);
Serial.println("Init...");
execute_CMD(0x3F, 0, 0); // Send request for initialization parameters
while (Serial1.available()<10) // Wait until initialization parameters are received (10 bytes)
delay(30);
Serial.println("Init Done");
After i plug the board, It stays stuck in the while() loop until i unplug the power of the mp3 player and replug it.
I have not a single clue on why, and i have a very low knowledge about particle boards, so i’m turning to you, grand masters of the community, to seek for some help.
Thank you for reading me, hoping to read you
Durss
