Sorry, this may have been covered. Can the Electron/Proton act as a a gateway? just ordered 4x Xenon and assumed can use my other particle devices for this…
Only a Argon, Boron, or Xenon + Ethernet adapter can be a gateway.
copy that, Argon on its way
Have you had any progress on this front? What you are doing sounds like almost exactly my use case and thus any possibility of me purchasing a Particle. I have held off for quite some time due to uncertainty about offline communications, especially mesh.
edit: I’ll add that I am almost completely uninterested in cloud functionality, OTA updates would be a perk, but are not necessary, and that low power local distributed communication is the priority.
I gave up on Particle’s desire of centralizing a mesh network and charging out the nose for basic mesh features.
Look up “ESP32 LoRa 32” and “ESP32 LoRa mesh”. You’ll have to roll your own for a lot of things, but it’s not bad. It at least works for long periods with less effort than the Particle Mesh stuff!
I had my first 4 node mesh up and posting data online in under 4 hours. It’s been running in it’s final config for the last 3 months without a hiccup.
