try this:
- Update VSCode - current version is
v1.44.2
, you are runningv1.27.2
(from VSCode’s main menu, select: Help > Check for Updates) - Update your Workbench extension - current version is
v1.11.0
, you are runningv1.4.8
(docs) - Disable the Arduino extension [id:
vsciot-vscode.vscode-arduino
] (docs) - Delete the
./target
directory within your project - Confirm your
project.properties
file does not include dependencies - Run the
Particle: Reset Environment
command (docs) - Restart VSCode
then
- Open your project (File > Open Folder)
- Click the
deviceOS@1.2.1-rc.3
entry in the status bar and select a newer version of the Device OS - e.g.v1.5.0
(see screenshot below) - Wait for the update Device OS dependency to install
- Run the
Particle: Compile application (local)
task (Terminal > Run Task, then click the Particle folder, and then select the task)
if that gets things working, you can try re-enabling the Arduino extension and re-compile to see if it causes any issues (it shouldn’t but best to rule it out explicitly).
hope it helps!
