I am confused about the wiring of the temperature sensor MCP9808 using particle photon board. When I run the code, it said the could not find the temperature sensor. Why is that? Is there any problem with the wiring?
@FahmedaKhanom, welcome to the forum! Which MCP9808 sensor board are you using and how do you have it connected to the Photon?
Hello, thank you for your response. My board is working right now. I tried so many days and it did not work and it started to work today
