Since the mode is AUTOMATIC, every time I restart the firmware a connection to the cloud is somehow established, but I would expect this to fail and enter listening mode after the first restart.
Strange, I’ve only ever had it connected it to one network, but it could be that I’d called setCredentials manually at some point during testing. Could it have saved multiple entries for the same network?
How would I determine the number of registered APs? It should just be 1, or at least 1 that I can presently connect to.
No, though there might have been at one time.
This works to delete the credentials.
Now that I’ve manually erased the creds, I’ll retry the snippet I posted above and see if that works.
Ok, I went through the steps to erase credentials manually and reconfigure it and everything now works as expected. After running the snippet above and resetting, the firmware enters listening mode. I’m not sure what went wrong the first time I tried this.
