I am having trouble with the following that was working fine with 0.7.0-RC.3 and now on 0.7.0-RC.4:
statusMessage("Clearing Stored WAP Credentials"); //V066 immediate feedback in case .hasCredentials takes time
if (WiFi.hasCredentials()) //button press is valid to clear credentials
timer3.start();
if (WiFi.clearCredentials())
statusMessage("All WAP Credentials Cleared");
Particle.disconnect();
WiFi.disconnect();
isTriedConnectOnce = false; //to ensure when reconnecting that particle connect is called once
WiFi.off();
WiFi.on();
else
statusMessage("Error - WAP Credentials Not Cleared"); //did not work!
int i = WiFi.hasCredentials()?13:0;
mainButtons(0, i, 3, 4);
connectionSymbol();
hangOn(2000);
clearStatusLine();
footerScreen(param.itemName);
else statusMessage("No Stored WAP Credentials");
This handler for a button to clear the wifi credentials appears to work except WiFi.hasCredentials() returns true. Any ideas what might be happening?
UPDATE: I couldn’t see why this was returning true to WiFi.clearCredentials() and true to WiFi.hasCredentials() immediately after. I thought I would try the same binary on a different photon. Hey presto - it works. A firmware load issue!!
