When i have requested from the core
Hi Guys,
I hope someone can help me.
Im trying to make a button, which can count with the spark core.
I did make the button so it works on the core, and i can get the information from the core.
Is there any way, i can reset the count i have on the core, when i get the value with CURL?
Any ideas?
My code: :smiley:
int status = 0;
int count ;
   Spark.variable("status", &status, INT);
   pinMode(D0, INPUT);
  if(digitalRead(D0) == HIGH){
      count++;
      delay(500);
      status = count;
Thank you!
You could provide a Spark.function() that does the resetting.
And since such a function does have an int return value, you could even forget the Spark.varilble()
If you call the fn with an empty parameter you just use the return value and when providing a param (e.g. โ€œresetโ€) you do just this.
int count = 0;
  Spark.function("doIt", doIt);
  pinMode(D0, INPUT_PULLUP);  // if your button pulls to ground
    count++;
    delay(500);
    //status = count;
int doIt(String param)
  if (param == "reset")
    count = 0;
  return count;
Wow, Thank you Scruffr,
I will test this as soon as possible! :smile:
