What is the difference between BIN file and ELF file?
The .bin files are a Particle software binary, packaged to be flashed to a device. There’s a header and a CRC to validate the binary.
The .elf files (Executable Linkable Format) are a product of building. They’re eventually translated into what becomes the .bin file by the linker.
Workbench doesn’t directly flash the device with .elf files, but it does use the .elf files for debugging because they contain the location of the symbols in memory so addresses can be mapped into readable symbols.
