What is Output of arm-none-eabi-size:?
I use wake on move which is the example in library called assettrackerRK and I also add another sensor on it. When I compile the code and it shows like this
I’ve never seen this before, is it a trouble? I don’t know what it is and what should I do?
It’s the size of your code, nothing to worry about.
Thank you :slight_smile:
