Memory profiling
I’m running out of memory on a project (region `APP_FLASH’ overflowed) and would like to see what is taking up the most space (and might even be unused). The project is based on a custom board with a P1 module. Searching the Guide/Docs returns no solutions, so I wonder - how can I profile a project?
The only way I know that can give me an idea of how much memory I use requires that I uncomment all the P1-specific constants and then use this to compile and get a very general memory analysis.
particle compile photon
I can compile this using:
particle flash (My P1's DeviceID)
that only produces the file in the cloud and flashes it to the device. I have seen mentions of the “arm-none-eabi-size” tool and I have it installed, but it seems it requires the .elf file. Is there a way for me to keep the compiled files, such as the ELF for analysis?
@jenschr, you would need to use the local toolchain to compile locally in order to produce the required files.
So I’d need to follow this guide? https://github.com/spark/firmware/blob/develop/docs/dependencies.md
Ok. Starting… :slight_smile:
First thing I stumble upon is what version of GCC I should use. The guide says version 4.9,. but the latest version available from ARM is 6.0. I could of course install the older one, but is this because it’s required or is the Guide just outdated @peekay123 ?
probably outdated, but I am unsure. It might be the one version they’ve tested enough to say “this works, use this one.”
@jenschr, I believe the “latest” gcc version to be supported is v5.3 or so. @BDub or @mdma might be able to shed some light here.
So I got this to work. I overcomplicated things by trying to install the latest GCC. Using Brew for installing it all went very smooth. I can now compile the firmware using the latest 0.6.2 release branch and I copied my project to the user apps directory. It compiles well after altering all the file paths in my project and I get an output like this:
text	   data	    bss	    dec	    hex	filename
5340	      8	   1604	   6952	   1b28	/myOut/myProject.elf
That output is quite a surprise? This is what I got back from the cloud compiler for the same project:
115868	    112	   3176	 119156	  1d174	/workspace/target/workspace.elf
What am I missing here? Shouldn’t building locally produce a somewhat similar output? Do I have to “flatten” the project structure in some way for my files to compile correctly? I’m compiling using this command in the “main” folder:
make APP=myProject PLATFORM_ID=8 TARGET_DIR=…/myOut/
Based on the questions I got to correct the inter-linked files in my project, it sleems like the compiler found all my files as it should, but the output looks very incorrect. This is the output from arm-none-eabi-size -A myOut/myProject.elf
section                  size         addr
.module_info               24    134873088
.text                    5272    134873112
.backup                     4   1073889280
.data                       4    536871680
.bss                     1604    536871684
.module_info_suffix        40    134878392
.module_info_crc            4    134878432
.debug_info           1539089            0
.debug_abbrev          127657            0
.debug_loc             149271            0
.debug_aranges           9928            0
.debug_ranges           19488            0
.debug_macro           232290            0
.debug_line            286880            0
.debug_str             637657            0
.debug_frame            42856            0
Total                 3052068
That’s none of my content and just some basic building blocks I presume? Any pointers as to how to proceed would be much appreciated!
GCC 5.3.1 is the latest supported and there are a few issues in the firmware repo regarding 5.4.1 and 6.x. to be worked out still. As always, we welcome PRs!
I now have gcc 4.9 installed and I’m still not getting a local compile that actually adds all my files. The output is very far from the memory info that I get back from doing “particle compile p1”.
I’m compiling by standing in the directory “spark/firmware/modules/” repository (from github) using the command:
make all PLATFORM=p1 APPDIR=../../../myProject
The compile looks to go fine. I see no errors, just that a lot of files are being linked in:
Building cpp file: ../../../myProject//src/InputManager.cpp
Invoking: ARM GCC CPP Compiler
mkdir -p ../build/target/user/platform-8-m/myProject/src/
The final output does not include any of the classes that are from my project (such as InputManager) and I get the following output:
6476	      8	   1780	   8264	   2048	../../../myProject/target/myProject.elf
When compiling from cloud, the output looks like this:
125276	   5536	   8876	 139688	  221a8	/workspace/target/workspace.elf
So… Something is missing I presume, but I have no idea where to dig further and I’m really at the memory limits so I need to resolve this now. Any pointers much appreciated! :slight_smile:
@jenschr, the local compile output is correct since your code is being compiled for modular firmware. As such, only your application code and any extra code/libraries not found in the system firmware will take up space. This is the beauty of having modular firmware!
The cloud compile, however, seems to put out stats for a monolithic build and seem to use values for the old Spark Core. I would not depend on these numbers. BTW, this is an old issue raised with Particle.
@peekay123 Ok, so then I have this working but I can’t seem to make any sense of the output from arm-none-eabi-size -A ./spark/firmware/myProject/target/myProject.elf:
section                  size         addr
.text                    6408    134873112
.data                       4    536871680
.bss                     1780    536871684
.module_info_suffix        40    134879528
.module_info_crc            4    134879568
.debug_info           1893539            0
.debug_abbrev          167609            0
.debug_loc             201297            0
.debug_aranges          11912            0
.debug_ranges           23480            0
.debug_macro           287949            0
.debug_line            394578            0
.debug_str             620582            0
.debug_frame            48896            0
Total                 3658106
If I understood this correctly, the -A should give me a map of how much memory each class is taking up. The output above just doesn’t make sense to me.
If omitting the -A I get this output:
6476	      8	   1780	   8264	   2048	/spark/firmware/myProject/target/myProject.elf
If I’m indeed only using 6476 out of 108000 bytes, why am I then running into memory issues with APP_FLASH overflowing? My .BIN file is just 6kb, but I’m definitely well above that. Hmmm…
@jenschr, I believe you need to compile from the “main” directory whereas “modules” is used for compiling the 3-part system firmware (though not sure it makes any difference). I have no idea why you would have APP_FLASH issues. Try compiling from “main” and flashing directly flashing of your bin file via DFU.
make clean all PLATFORM=p1 APPDIR=../../../myProject program-dfu
Hmm… No. Still getting the same output when compiling from that directory?
Did you flash it to your device? Can you show the exact output from your compile?
@peekay123 thanks for helping out! I did not flash it to the device yet. The complete output during compilation is here:
https://dl.dropboxusercontent.com/u/20621/compilation_process.txt
@jenschr, try flashing your code!
I flashed it now, and surely enough - the 6Kb .bin file did not contain the same as the one that is 101Kb :wink:
It’s basically flashed with nothing according to the output of “arm-none-eabi-size -A”.
What I should see is a listing of all the classes used in my project and how much they each take up. Right?
Can you provide a list of files and the directory structure? Seems like not everything is being linked in.
Looking at line 3 in the output file (with the “rm -f”) I can see .o files for all the classes in my project, so I’m pretty sure it’s all there. All these files have both a header (.h) and a body (.cpp) file. The files that are not listed as being in the “src” folder are in the “lib” folder. “lib” and “src” are both folders on the root level in my project directory (standard Particle project setup).
These are the files listed and I can’t find any of them in the output from arm-none-eabi-size:
/myProject/src/Fans.o
/myProject/src/Fire.o
/myProject/src/InputManager.o
/myProject/src/Internetwork.o
/myProject/src/Motors.o
/myProject/src/ScreenManager.o
/myProject/src/Model/PtHundred.o
/myProject/src/Model/Process.o
/myProject/src/Model/ValueObjects.o
/myProject/src/Screens/BaseScreen.o
/myProject/src/Screens/DebugScreen.o
/myProject/src/Screens/PidScreen.o
/myProject/src/Screens/RootScreen.o
/myProject/src/Screens/SettingsScreen.o
/myProject/src/Screens/StartupScreen.o
/myProject/AccelStepperSpark/src/AccelStepper.o
/myProject/AccelStepperSpark/src/AccelStepperSpark.o
/myProject/DACx311/src/DACx311.o
/myProject/GSL1680/src/GSL1680.o
/myProject/MAX6639/src/max6639.o
/myProject/MCP3424/src/MCP3424.o
/myProject/MQTT/src/MQTT.o
/myProject/PID/src/PID_v1.o
/myProject/RA8875/src/RA8875.o
/myProject/RA8875/src/fonts/GothamXL16.o
/myProject/RA8875/src/fonts/GothamXL32.o
/myProject/SparkIntervalTimer/src/SparkIntervalTimer.o
/myProject/TCA6408/src/TCA6408.o
/myProject/src/Fans.o.d
/myProject/src/Fire.o.d
/myProject/src/InputManager.o.d
/myProject/src/Internetwork.o.d
/myProject/src/Motors.o.d
/myProject/src/ScreenManager.o.d
/myProject/src/Model/PtHundred.o.d
/myProject/src/Model/Process.o.d
/myProject/src/Model/ValueObjects.o.d
/myProject/src/Screens/BaseScreen.o.d
/myProject/src/Screens/DebugScreen.o.d
/myProject/src/Screens/PidScreen.o.d
/myProject/src/Screens/RootScreen.o.d
/myProject/src/Screens/SettingsScreen.o.d
/myProject/src/Screens/StartupScreen.o.d
/myProject/AccelStepperSpark/src/AccelStepper.o.d
/myProject/AccelStepperSpark/src/AccelStepperSpark.o.d
/myProject/DACx311/src/DACx311.o.d
/myProject/GSL1680/src/GSL1680.o.d
/myProject/MAX6639/src/max6639.o.d
/myProject/MCP3424/src/MCP3424.o.d
/myProject/MQTT/src/MQTT.o.d
/myProject/PID/src/PID_v1.o.d
/myProject/RA8875/src/RA8875.o.d
/myProject/RA8875/src/fonts/GothamXL16.o.d
/myProject/RA8875/src/fonts/GothamXL32.o.d
/myProject/SparkIntervalTimer/src/SparkIntervalTimer.o.d
/myProject/TCA6408/src/TCA6408.o.d
/myProject/libuser.a
@jenschr, does you code make calls to the libraries? The object files are always produced but the linker will only bring in the code that is used in the final .bin file.
