So im plannign on controlling an external device via serial that takes hex values. Using a simple bit of test code ive noticed that the array is only ever a size of 4 and thats all that gets transmitted to the device.
Here is the code…
#define TIMEOUT 2000
unsigned long timer;
const char cmdTosend[] = {0xAA,0x11,0x01,0x01,0x01,0x14};
Serial1.begin(9600);
sendHex(cmdTosend);
timer = millis();
while (!Serial.available() && millis() <= timer + TIMEOUT) SPARK_WLAN_Loop();
void sendHex(const char *cmd)
Serial.write("Size of array is " + String(sizeof(cmd)));
for(int i = 0; i <sizeof(cmd); i++)
Serial1.write(cmd[i]);
Not sure what im doing wrong. Any advice much appreciated
I would use Serial.printlnf("Size of array is %d", sizeof(cmd)); instead of Serial.write();
Better if you get the sizeof char array once - int sizeOfCmd = sizeof(cmd);
Then
Serial.printlnf("Size of array is %d", sizeOfCmd);`
Serial.write(cmd, sizeOfCmd);
If you want to check it has been sent then int bytesCmdSent = Serial.write(cmd, sizeOfCmd);
And Serial.printlnf("Size of array sent is %d", bytesCmdSent);
Thanks @armor ive made the changes and changed the array to a byte array, however it still only returns a value of 4 for the length of the array.
If i change the array to {0xAA,0x11,0x01} it returns the lenght as 4 but actually sends 0xAA 0x11 0x01 0x53 (as recieved by a PC)
Even if i set the array to 1 (0xAA) it still shows as 4 but sends 0xAA 0x53 0x69 0x7A
Very confusing…
Here is the updated code. I am a bit of a novice but learning fast
SYSTEM_THREAD(ENABLED);
const byte cmdTosend[] = {0xAA}; //,0x01,0x01,0x14};
while (!Serial.available()) delay(10);
if (millis () - timer >= TIMEOUT){
timer = millis();
sendHex(cmdTosend);
void sendHex(const byte *cmd)
int bytesCmdSent = Serial1.write(cmd, sizeOfCmd);
Serial.printlnf("size of array sent %d", bytesCmdSent);
It is perfecly normal that a pointer - and cmd is nothing else than a mere pointer - will give you a size of four bytes. const byte *cmd is not the same thing as your cmdTosendarray.
That is common C behaviour and also the reason why standard C functions that take an array pointer also demand the size of the array to be passed.
Passing a pointer is only passing the address but no meta data about the “thing” it points to.
I think you should change sendHex to also take in the length of the array, since calling sizeof on a pointer to byte will return the size of the pointer (4 bytes), and not the length of the byte array.
void sendHex(const byte *cmd, unsigned int length)
Since you’re not passing the length of the array, any data printed after 0xAA is garbage, since you specified Serial1.write to print 4 bytes.
Ah of course! that makes perfect sense. I was confusing size with length. So in the past using C# there is a method to get an array length by using myarray.length() for example. The equivilent in C++ seems to be int arrayLen = sizeof(myarray) / sizeof(myarray[0]);
So I tried it out and bingo I can now get the size of the array of hex values i want to send and it sends correctly.
Many thanks for the pointers (sorry about the pun) guys. I really apprecite it.
Here is my working test sample if anyone is interested.
const byte cmdTosend[] = {0xAA,0x01,0x01,0x14,0x12,0xA1};
timer = millis();
// get the number of items in the array
int len = sizeof(cmdTosend) / sizeof(cmdTosend[0]);
// send it
sendHex(cmdTosend, len);
//show the length of the array thats been passed in
Serial.printlnf("Size of array is %d", length);
// send to the device.
int bytesCmdSent = Serial1.write(cmd, length);
