Hi!,
i need to share a variable from a Photon device through the cloud in order to get it from a node.js server and store it in a DB. The variable is defined as an array of hex values: char sample_data2 [] = {0x00, 0x00, 0x01, 0x00, …} … how could i share it with Particle.variable()?
thanks
Here’s some code that translates an array of bytes into a sequence of hex digits in a string. This will work up to about 310 or so bytes of data, based on the limit of the string size for a particle variable.
#include "Particle.h"
void updateHexData(const byte *data, size_t dataLength); // forward declaration
const byte testData[] = {0x00, 0x00, 0x01, 0x00, 0xff, 0x65, 0x66, 0x67, 0x31, 0x32};
String sensorData;
// Register the variable once in setup
Particle.variable("sensordata", sensorData);
// This just updates the data once. Normally, you'd periodically call this when you
// read the sensor. Updating this changes the data locally so when it's requested,
// fresh data is returned. It's OK to call this frequently as it doesn't cause
// data to be pushed to the cloud.
updateHexData(testData, sizeof(testData));
void updateHexData(const byte *data, size_t dataLength) {
// Reserve buffer space so we only need to do one memory allocation when appending to sensorData
// Note that Particle.variable has a limit of 622 bytes, so the maximum dataLength is 310 or so bytes.
sensorData.reserve(dataLength * 2 + 1);
// This is where we store the one byte of hex data (two bytes of ASCII 0-9 and a-f).
char hexBuf[4];
// Convert the input data to hex
for(size_t ii = 0; ii < dataLength; ii++) {
snprintf(hexBuf, sizeof(hexBuf), "%02x", data[ii]);
if (ii == 0) {
sensorData = hexBuf;
else {
sensorData += hexBuf;
And here’s what the value looks like in the variable
$ particle get test4 sensorData
00000100ff6566673132
Thanks @rickkas7! … i will try that way.
best regards
The reason I selected hex format is that you mentioned using node.js, and it’s really easy to convert from a hex string into a node Buffer object, which will allow you to access the underlying binary data easily.
var buf = new Buffer(hexVariableString, "hex")
