Weird TMP36 results
Hi all,
I am using a TMP36 Temperature sensor but getting some really strange results…prob me being silly but not only am I seeing large temperatures (109 deg C apparently) the sensor also seems to work in reverse i.e. when it should get colder it says its getting hotter and visa versa.
I suspect I have the code wrong…see below (which was copied from somewhere)
#include <math.h>
const int PULLUP_RES = 100000; // in Ohm( 100kOm )
const double BETA = 4390; // in K for Semitec 104 GTA-2
const double THERMISTOR_RES = 100000; // in Ohm
const double THERMISTOR_NOM_TEMP = 25; // Celsius, C
 thermister_temp(analogRead(A0));
 delay(1000);
void thermister_temp(int aval)
 double R, T;
R = (double) PULLUP_RES / ( (4095 / (double) aval ) - 1 );
 T = 1 / ( ( 1 / (THERMISTOR_NOM_TEMP + 273.15 )) + ( ( 1 / BETA) * log ( R / THERMISTOR_RES ) ) );
 T -= 273.15; // converting to C from K
 // return degrees C
 Spark.publish("Temperature", String(T) + " °C");
Any help appreciated.
@Nnpnew the TMP36 is a bit finicky so check this thread out to see how to improve your results
EDIT: Looking at your code, yeah that's for a thermistor. Check out the code in the thread I mentioned :wink:
This is the formula I use for the TMP36:
float getTempF() {
	int tempValue = analogRead(TMP36_PIN);
	// Analog inputs on the Photon have values from 0-4095, or
	// 12-bit precision. 0 = 0V, 4095 = 3.3V, 0.0008 volts (0.8 mV) per unit
	// The temperature sensor docs use millivolts (mV), so use 3300 as the factor instead of 3.3.
	float mV = ((float)tempValue) * 3300 / 4096;
	// According to the TMP36 docs:
	// Offset voltage 500 mV, scaling 10 mV/deg C, output voltage at 25C = 750 mV (77F)
	// The offset voltage is subtracted from the actual voltage, allowing negative temperatures
	// with positive voltages.
	// Example value=969 mV=780.7 tempC=28.06884765625 tempF=82.52392578125
	// With the TMP36, with the flat side facing you, the pins are:
	// Vcc | Analog Out | Ground
	float tempC = (mV - 500) / 10;
	float tempF = (tempC * 9) / 5 + 32;
	return tempF;
