Hi. We have a django site hosted on on heroku. We made an endpoint
/events/<device_id>
set up a webhook integration called tracking_event w the following form data
"event": "{{{PARTICLE_EVENT_NAME}}}",
"data": "{{{PARTICLE_EVENT_VALUE}}}",
"coreid": "{{{PARTICLE_DEVICE_ID}}}",
"published_at": "{{{PARTICLE_PUBLISHED_AT}}}"
Hitting ‘test integration’ button publishes to our endpoint on heroku. My heroku logs of request.POST look like:
2020-09-25T21:58:19.955482+00:00 app[web.1]: [25/Sep/2020 21:58:19,955]
<QueryDict: {
'event': ['tracking_event'],
'data': ['test-event'],
'published_at': ['2020-09-25T21:58:19.698Z'],
'coreid': ['api']}>
2020-09-25T21:58:19.957044+00:00 app[web.1]: 10.45.161.126 - - [25/Sep/2020:21:58:19 +0000] "POST /events/api HTTP/1.1" 200 12 "-" "ParticleBot/1.1 (https://docs.particle.io/webhooks)"
I added the code that it says to add to firmware (setup, callback and publish) without changing anything. But I am not getting published events from firmwear to hit that heroku endpoint. Any idea what else needs to be done?
Sorry for noob question
