I’m facing an issue when i’m sending a HTTPS postrequest agains an Azure cloud server.
The post response is like: ( i sensored some fields here)
{"data":"{\"error\":\"invalid_client\"}","ttl":"60","published_at":"[SENSOREDTIMESTAPM]","coreid":"particle-internal","name":"hook-response/nannannaa/0"}
here’s the hook:
"eventName": "webhook",
"url": "https://host.com/oauth2/token",
"requestType": "POST",
"rejectUnauthorized": "false",
"headers": {
"Host": "host.com",
"Content-Type": "application/json; charset=utf-8"
"json":
"grant_type": "client_credentials",
"client_id": "[client_id]",
"client_secret": "[client_secret",
"scope": "Scope"
"mydevices": "true"
When i change the enpoint to http:// i can se some response from azure so i suspect some kind of SSL issue with the invalid_client behavior.
The post request is tested with fiddler as content-type :x-www-form-urlencoded and it works correctly.
Do you know what the problem may be ?
