I have a few questions about how webhooks are being created on the Particle dashboard.
At the top of the New Webhook page are icons for Webhook Builder and Custom JSON. If I enter, say, Event Name and URL in Webhook Builder and then switch over to Custom JSON, those entries do not show up in the Custom JSON, and vice-versa (if I enter “event”:“Try This Now” and switch over to Webhook Builder, the Event Name field is still blank). So what exactly is the relationship between the two? And is there a list somewhere of exactly what fields can go in the Custom JSON?
In connecting to ThingSpeak, under Advanced Settings I was able to send custom data using both the Form and with JSON, entering “api_key”:“my_api_key” and “field1”:"{{PARTICLE_EVENT_VALUE}}", so which should I use and why?
I read over a tutorial that a user had written on the Webhook Responses, and sorta, kinda understood it – but there seems to be very little in the documentation about it. Is there any other source, or are there any plans to expand that section? Needless to say, I am in favor of the latter
Is it possible to edit a Webhook once it has been created?
Is it is possible to see the web service request (in raw HTTP) that is going to be sent to the web service?
Sorry to be so long winded, but as you can tell I am somewhat at sea with regards to this: I think the abstraction of detail is actually hurting rather than helping (at least for me, in this one particular area).
