Web IDE expired token
Hey @jgoggins,
It seems weird that i’m not kicked out even though the access token has expired ‘according to the warning’
I think the IDE has its own token separate from the user access_token, is that right @jgoggins ?
Good question @kennethlimcp.
That is correct @Dave, api.spark.io uses a different access token than the IDE, that’s why it’s not kicking you out.
