Howdy
A sketch of mine that used to compile OK in the Web IDE, no longer is. I’m getting this …
obj/src/stm32_it.o: In function `TIM2_IRQHandler':
/spark/compile_server/shared/workspace/worker_2/core-firmware/build/../src/stm32_it.cpp:527: multiple definition of `TIM2_IRQHandler'
hardware.o:/spark/compile_server/shared/workspace/worker_2/core-firmware/build/hardware.cpp:107: first defined here
My program does declare TIM2_IRQHandler, thusly …
extern "C" void TIM2_IRQHandler()
… though in a separate file pair, hardware.cpp/h
Way back some time, I was unable to include my own TIM2_IRQHandler in the project’s main .ino file. I was advised that putting it in a separate, included file would solve the problem, which it did. But now it isn’t working, again – for a different reason, perhaps?
EDIT: I should mention for clarity that the code DOES compile just fine locally, using command-line tools.
Anyone got any clues?
Thanks.
