Web control leds error
Hello,
Hello I am new to spark and I’m learning, yesterday managed to make the code below work but today it no longer works, do not know if I changed something and not realized, already copied and pasted the site but clicking the button one or two nothing happens. If I enter the code and put D0 or D1 for high works, just does not work the web
HTML FILE:
<br><br>
<button id="led1onbutton"  onclick="switchLED(1,1)">LED 1 On</button>
<button id="led1offbutton"  onclick="switchLED(1,0)">LED 1 Off</button>
<br><br>
<button id="led2onbutton"  onclick="switchLED(2,1)">LED 2 On</button>
<button id="led2offbutton"  onclick="switchLED(2,0)">LED 2 Off</button>
<br><br>
<script type="text/javascript">
  var deviceID    = "mydevicenumber";
  var accessToken = "mytoken";
  var setFunc = "led";
  function switchLED(ledn,newValue) {
    var paramStr = "l" + ledn.toString();
    if (newValue==1) {
       paramStr = paramStr + ",HIGH";
    } else {
      paramStr = paramStr + ",LOW";
var requestURL = "https://api.spark.io/v1/devices/" +deviceID + "/" + setFunc + "/";
    $.post( requestURL, { params: paramStr, access_token: accessToken });
</script>
SPARK CODE
int led1 = D0;
int led2 = D1;
Spark.function(“led”, ledControl);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
int ledControl(String command)
int state = 0;
int pinNumber = (command.charAt(1) - ‘0’) - 1;
if (pinNumber < 0 || pinNumber > 1) return -1;
if(command.substring(3,7) == “HIGH”) state = 1;
else if(command.substring(3,6) == “LOW”) state = 0;
else return -1;
digitalWrite(pinNumber, state);
return 1;
Solution my token is expired
