Simple Web API failing
I have never worked with a web api before (I generally work with client side programming). However, I have followed the instructions from the examples page and it keeps saying the code is wrong. Help please, here is the code.
// Controlling LEDs over the Internet
// name the pins
int led1 = D0;
int led2 = D1;
// This routine runs only once upon reset
//Register our Spark function here
Spark.function(“led”, ledControl);
// Configure the pins to be outputs
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
// Initialize both the LEDs to be OFF
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
// This routine loops forever
// Nothing to do here
// This function gets called whenever there is a matching API request
// the command string format is l,
// for example: l1,HIGH or l1,LOW
// l2,HIGH or l2,LOW
int ledControl(String command)
int state = 0;
//find out the pin number and convert the ascii to integer
int pinNumber = command.charAt(1) - ‘0’;
//Sanity check to see if the pin numbers are within limits
if (pinNumber < 0 || pinNumber > 1) return -1;
// find out the state of the led
if(command.substring(3,7) == “HIGH”) state = 1;
else if(command.substring(3,6) == “LOW”) state = 0;
else return -1;
// write to the appropriate pin
digitalWrite(pinNumber, state);
return 1;
POST /v1/devices/{DEVICE_ID}/led
EXAMPLE REQUEST IN TERMINAL
Core ID is 0123456789abcdef01234567
Your access token is 1234123412341234123412341234123412341234
curl https://api.spark.io/v1/devices/0123456789abcdef01234567/led
-d access_token=1234123412341234123412341234123412341234
-d params=l1,HIGH
Hi @1rudster,
No worries, make sure your code stops before this line:
That line isn't part of the code you're writing, and is meant to show you what the web request should look like.
David
Thanks so much! Happy New Year to you and your companion cube!
