Hi there,
If you are having some issues with some of the tutorials, I noticed something a bit weird that caused me an issue. Hope this helps.
First, in the Controlling LEDs over the NET example, I added the LED to pin 0 and set up the internal LED on pin 7.
// Controlling LEDs over the Internet
// name the pins
int led1 = D0;
int led2 = D7;
// This routine runs only once upon reset
//Register our Spark function here
Spark.function("led", ledControl);
// Configure the pins to be outputs
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
// Initialize both the LEDs to be OFF
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
// This routine loops forever
// Nothing to do here
// This function gets called whenever there is a matching API request
// the command string format is l<led number>,<state>
// for example: l1,HIGH or l1,LOW
// l2,HIGH or l2,LOW
int ledControl(String command)
int state = 0;
//find out the pin number and convert the ascii to integer
int pinNumber = (command.charAt(1) - '0') - 1;
//Sanity check to see if the pin numbers are within limits
if (pinNumber < 0 || pinNumber > 8) return -1;
// find out the state of the led
if(command.substring(3,7) == "HIGH") state = 1;
else if(command.substring(3,6) == "LOW") state = 0;
else return -1;
// write to the appropriate pin
digitalWrite(pinNumber, state);
return 1;
No major changes there, However, I noticed that if you pass l1, the led on D0 lights, but if you pass l2, the internal does not. Thatâs because the code is looking for pin number which doesnât seem to be zero indexed. Itâs a bit odd and confusing since you define the pins as led1 and led2, so you think that 1 and 2 get mapped, but thatâs not what the code does. My version above will pass the HIGH to pin d0 or d7⌠if you send it l1 or l8. Which brings me to my next helpful hint.
There is a bit of HTML code in the Variables and Functions (part1) tutorial that doesnât make any sense because it pushes to the function âLEDâ, which is not defined in âVariables and Functionsâ. However, that HTML is hella handy if you want to turn on the LED using the net example without curl (shudder).
Hereâs my adapted code that turns on the internal LED if you are using my adapted code above.
<!-- Replace your-device-ID-goes-here with your actual device ID
and replace your-access-token-goes-here with your actual access token-->
<center>
<br>
<br>
<br>
<form action="https://api.particle.io/v1/devices/device id here/led?access_token=put your access token here" method="POST">
Tell your device what to do!<br>
<br>
<input type="radio" name="args" value="l8,HIGH">Turn the LED on.
<br>
<input type="radio" name="args" value="l8,LOW">Turn the LED off.
<br>
<br>
<input type="submit" value="Do it!">
</form>
</center>
Anyhoo, hope that helps save some confusion. The tutorial probably could be cleaned up a bit, since thereâs a bunch of superfluous code in there, but⌠Itâs bedtime
