Allo gang, I wanted to share my first project. It’s somewhat a modified version of the annotated spark example. I have 3 LED connected to A4, A5, and A6.
// name the pins
int led1 = A4;
int led2 = A5;
int led3 = A6;
//Register our Spark function here
Spark.function("led", ledControl);
// Configure the pins to be outputs
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
// Initialize LEDs to be OFF
analogWrite(led1, 255);
analogWrite(led2, 255);
analogWrite(led3, 255);
// nothing here?
int ledControl(String command)
//find out the pin number and convert the ascii to integer
int pinNumber = command.charAt(0) - '0';
//Sanity check to see if the pin numbers are within limits
if (pinNumber < 0 || pinNumber > 4) return -1;
// convert the string to an int
// the command to send to API would be
// curl https://api.spark.io/v1/devices/0123456789abcdef01234567/led \
// -d access_token=1234123412341234123412341234123412341234 \
// -d params=1,100
// params are (123),(0-255)
String x = command.substring(2);
int state = x.toInt();
if (pinNumber == 1)
analogWrite(led1, state);
else if (pinNumber == 2)
analogWrite(led2, state);
else if (pinNumber == 3)
analogWrite(led3, state);
else
return -1;
return 1;
I just started coding so this may look horrible to experience coder. I can take some critiquing.
Ill be looking at adding “features” like presets in the near future. Hope this was helpful to anyone.
