We need to collect billing information, which we cannot do securely via the command line. how to solve that problem?
HI, i have a big problem with my particle i cannot connect USB, i have that problems.
 _ __             _   _      _
| '_ \  __ _ _ __| |_(_) ___| | ___
| |_) |/ _` | '__| __| |/ __| |/ _ \
|  __/| (_| | |  | |_| | (__| |  __/
|_|    \__,_|_|   \__|_|\___|_|\___|
                 https://particle.io
> Setup is easy! Let's get started...
> It appears as though you are already logged in as jlopez@awto.cl
? Would you like to use this account? Yes
! PROTIP: Hold the MODE/SETUP button on your device until it blinks blue!
! PROTIP: Please make sure you are connected to the internet.
> I have detected a Electron connected via USB.
? Would you like to continue with this one? Yes
! Electron(s) cannot be setup via the CLI.
! We need to collect billing information, which we cannot do securely via the command line.
! Please visit https://setup.particle.io to setup your Electron.
help me please!!!
You cannot set up an Electron using the Particle CLI.
You need to use https://setup.particle.io or the mobile apps to activate your SIM card.
You can use the Particle CLI to flash code to your Electron after you’ve set it up on the web site without using particle setup. The particle setup command is only for Wi-Fi devices and is not necessary for Electrons.
