Has anyone been able to integrate and have a working DSI display with waveshare 7inch DSI display? I have a display that works with RPI but not with tachyon. I followed the procedure in this How to Modify the Device Tree | Particle Developer but no luck.
Hi @mayur
Apologies for the delay. What Ubuntu version are you running?
As far as I know, the Waveshare 7-inch display is supported on Tachyon Ubuntu 24.04.
The team's working on more display support in 20.04. but I believe it's limited to the 4" screen for now.
Hi, I am running Ubuntu 24.04, tachyon-ubuntu-24.04-RoW-desktop-1.1.43 image. As you said, the display should work but I haven't been able to get the display working.
I tried flashing the tachyon-ubuntu-24.04-RoW-desktop-1.2.2 image, but the installation fails at
[█████████████████████████] 98% | Flashing module: core_nhlos_a (1280/43520 sectors)
i tried building U-boot with this changes. I changed the clock frquency to 100khz. The display is still not working. Also I can't find the display on the i2c detection as well.
