I have two buttons here (digital inputs on D2 and D3). When it’s sleeping you can press a button to wake it up. This is that simple, center rectangle.
Then I tried adding the delay circuit on the right (but without the transistor at the top) so that when you press the D3 button while it’s in sleep mode, the pin is held high for a few extra seconds while it wakes up, allowing the firmware to read the button press and take action.
This worked great! But now quick presses of the button are impossible since the cap debounces it a few seconds. So I tried adding the lower portion to disable the right circuit when the power was on. The firmware keeps D6 HIGH when it’s running, and LOW in sleep mode, then the inverter flips it. I added the top-most transistor to the delay circuit on the right to try to remove it when the D6 was high.
Does anyone see problems, conceptually with this? And if not, any specific bugs or misunderstandings?
I’m having a heck of a time getting this idea to work.
