I am using VL6180X Time of Flight sensor with Argon, and I am looking for a more precise sensor if anyone has used more accurate sensor I can use in industry. Accuracy of 1 mm distance ranging will be great.
Many Thanks
Many Thanks
@majj_11 ,
I have been testing with the VL53L1X which gives you a number of settings to maximize range, sensitivity and accuracy (pick two!).
This device also supports an interrupt functionality that can support low-power operations - a big draw for me.
https://www.st.com/resource/en/datasheet/vl53l1x.pdf
Hope this helps,
Chip
Thanks a lot i will try it and i am diffidently looking for the accuracy and sensitivity.
Thank you
