@peekay123 It should arrive on your doorstep Tuesday
@peekay123
Ithink it’s here:
I’ve been looking at these functions for the interrupt problem, but have gotten nowhere yet:
Status = VL53L0X_SetGpioConfig(pMyDevice, 0, //0 is GPIO1
VL53L0X_DEVICEMODE_GPIO_DRIVE,
VL53L0X_GPIOFUNCTIONALITY_THRESHOLD_CROSSED_LOW,
VL53L0X_INTERRUPTPOLARITY_LOW);
FixPoint1616_t thresholdL = 200.0; //for example
FixPoint1616_t thresholdH = 400.0; //for example
Status = VL53L0X_SetInterruptThresholds(pMyDevice,
thresholdL, thresholdH);
ADD: FWIW, when I added that code (pretty much anywhere) in the Adafruit_VL53L0X::rangingTest
function, I do get apparent interrupt activity on the GPIO1 pin but they are indiscriminate and not associated with any particular range value regardless of a later call (or not) to:
VL53L0X_ClearInterruptMask(pMyDevice,
0);//this function doesn't care
@peekay123
Also, this document from ST seems to have the most info, though still woefully inadequate for my basic level:
@bpr, the VL53L0X_SetGpioConfig() function seems to be missing a Status =
near its end:
if (Status == VL53L0X_ERROR_NONE)
/* MISSING --> */ Status = VL53L0X_SETDEVICESPECIFICPARAMETER(Dev,
Pin0GpioFunctionality, Functionality);
Status = VL53L0X_ClearInterruptMask(Dev, 0);
Also, you are correct. As written, VL53L0X_ClearInterruptMask() ignores the InterruptMask and simply clears both the ranging and error interrupt bits. Not sure why that was done that way but hey, it should clear the ranging interrupt regardless. More playing tomorrow.
@peekay123
I’ve definitely run into several walls with the device code.
To get the device to emit an interrupt in a given condition, I assume (maybe erroneously?) we want the config to use
but when I set that, it refuses to use any other gpiofunctionality other than
VL53L0X_GPIOFUNCTIONALITY_NEW_MEASURE_READY
I was thinking we would instead likely want one of the THRESHOLD settings but it won’t comply.
Furthermore when I use
as the last setting, then later call the getconfig, it indicates the reverse (HIGH) was set (??).
And I’m befuddled about the
function. It appears one needs to use
20 * 65536 (for a setting, e.g., of 20) for a reason I don’t understand.
It’s beyond me! Is the code port still in need of massaging possibly?
Another gotcha for me was discovering that several settings seem to “stick” unless you power cycle the device.
And the "Status = " you mention above isn’t really missing, I don’t think, because it looks like an alias for
PALDevDataSet
which doesn’t return anything, and inserting “Status =” seems to block making the settings, if I’m not mistaken.
Whew! Like I said, it’s beyond me!
@bpr @peekay123 @ScruffR Does this code help any with the Interrupts?
General Functions : https://developer.mbed.org/users/mjarvisal/code/vl53l0x_api/docs/tip/group__VL53L0X__general__group.html#ga53faed55c6951878c58b6a19d613ee9b
All Functions: https://developer.mbed.org/users/mjarvisal/code/vl53l0x_api/docs/tip/group__VL53L0X__cut11__group.html
@peekay123 @ScruffR @RWB @shiv
Anyone get anywhere with the vl53l0x interrupt problem yet. I sure haven’t! Completely lost, myself.
@BPR Funny you ask right now because I’m searching high and low trying to figure it out also
Here is a guy who put some code together to use the sensor with the Teensy 3, maybe there is something in there that hints on how to change the Interrupt settings:
Specifically these lines:
“I tried to get the interrupt to work but I am missing something still.” he says, so he’s in the same boat with us
@bpr We’re going to have to track somebody down that can help us out.
Geesh, the Adafruit library which is taken from an Mbed library is a mess IMO with the poorest of documentation which is a great disappointment. I’m working on the interrupt stuff and will post when I have something to report.
@RWB, @ScruffR, I was able to get the range interrupt working by adapting the kriswiner code that @RWB posted above. So far, I was able to set a “high” limit which only creates interrupts when the distance measured is ABOVE the threshold I set. At least this proves that interrupts work.
I am not able to make sense of the CROSSED_LOW and CROSSED_OUT interrupts work mostly because I’m not sure how these work in reference to the set thresholds. However, I was able to get the CROSSED_HIGH interrupt going with a low and high threshold so the interrupt only fired when an object was within the threshold distances. HOWEVER, even though I set a low of 350mm and a high of 150mm, the high point ends up begin 250mm. Bottom line is a lot of playing around is necessary until the documentation for this sensor catches up.
/* VL53L0X_t3 Basic Example Code
by: Kris Winer
date: August 29, 2016
license: Beerware - Use this code however you'd like. If you
find it useful you can buy me a beer some time.
Demonstrates basic VL53L0X proximity sensor functionality including parameterizing
the register addresses, initializing the sensor, getting range data out.
Eventually will use this sensor to recognize hand gestures and control
functions through a microcontroller like Teensy 3.1.
Sketch runs on the Teensy 3.1.
This sketch is intended specifically for the VL53L0X breakout board and Add-On Shield for the Teensy 3.1.
It uses SDA/SCL on pins 17/16, respectively, and it uses the Teensy 3.1-specific Wire library i2c_t3.h.
The Add-on shield can also be used as a stand-alone breakout board for any Arduino, Teensy, or
other microcontroller.
The sensor communicates via I2C at 400 Hz or higher.
SDA and SCL have 2K2 pull-up resistors (to 3.3 V) on the breakout board.
Hardware setup:
Breakout Board --------- Arduino/Teensy
3V3 ---------------------- VIN or any digital GPIO pin with digitalWrite(HIGH)!
SDA -----------------------A4/17
SCL -----------------------A5/16
GND ---------------------- GND or any digital GPIO pin with digitalWrite(LOW)!
Note: The VL53L0X breakout board is an I2C sensor and uses the Arduino Wire or Teensy i2c_t3.h library.
Even though the voltages up to 5 V, the sensor is not 5V tolerant and we are using a 3.3 V 8 MHz Pro Mini or a 3.3 V Teensy 3.1.
We are also using the 400 kHz fast I2C mode by setting the TWI_FREQ to 400000L /twi.h utility filefor the Pro Mini useage.
The Teensy has no internal pullups and we are using the Wire.begin function of the i2c_t3.h library
to select 400 Hz i2c speed.
#include "Particle.h"
#define I2C_NOSTOP true
// VL53L0X Data Sheet
// http://www.st.com/content/ccc/resource/technical/document/datasheet/group3/b2/1e/33/77/c6/92/47/6b/DM00279086/files/DM00279086.pdf/jcr:content/translations/en.DM00279086.pdf
/* Device register map */
/** @defgroup VL53L0X_DefineRegisters_group Define Registers
* @brief List of all the defined registers
// Record the current time to check an upcoming timeout against
uint16_t timeout_start_ms;
uint16_t io_timeout;
#define startTimeout() (timeout_start_ms = millis())
// Check if timeout is enabled (set to nonzero value) and has expired
#define checkTimeoutExpired() (io_timeout > 0 && ((uint16_t)millis() - timeout_start_ms) > io_timeout)
// These are the registers defined in ST Microelecronics' API
// Note the registers have 2-bytes addresses, but for some reason I can only get sensible data out of the VL53L0X when
// I assume an 8-bit register address using only the LSbyte
#define VL53L0X_REG_SYSRANGE_START 0x0000
/** mask existing bit in #VL53L0X_REG_SYSRANGE_START*/
#define VL53L0X_REG_SYSRANGE_MODE_MASK 0x0F
/** bit 0 in #VL53L0X_REG_SYSRANGE_START write 1 toggle state in
* continuous mode and arm next shot in single shot mode */
#define VL53L0X_REG_SYSRANGE_MODE_START_STOP 0x01
/** bit 1 write 0 in #VL53L0X_REG_SYSRANGE_START set single shot mode */
#define VL53L0X_REG_SYSRANGE_MODE_SINGLESHOT 0x00
/** bit 1 write 1 in #VL53L0X_REG_SYSRANGE_START set back-to-back
* operation mode */
#define VL53L0X_REG_SYSRANGE_MODE_BACKTOBACK 0x02
/** bit 2 write 1 in #VL53L0X_REG_SYSRANGE_START set timed operation
* mode */
#define VL53L0X_REG_SYSRANGE_MODE_TIMED 0x04
/** bit 3 write 1 in #VL53L0X_REG_SYSRANGE_START set histogram operation
* mode */
#define VL53L0X_REG_SYSRANGE_MODE_HISTOGRAM 0x08
#define VL53L0X_REG_SYSTEM_THRESH_HIGH 0x000C
#define VL53L0X_REG_SYSTEM_THRESH_LOW 0x000E
#define VL53L0X_REG_SYSTEM_SEQUENCE_CONFIG 0x0001
#define VL53L0X_REG_SYSTEM_RANGE_CONFIG 0x0009
#define VL53L0X_REG_SYSTEM_INTERMEASUREMENT_PERIOD 0x0004
#define VL53L0X_REG_SYSTEM_INTERRUPT_CONFIG_GPIO 0x000A
#define VL53L0X_REG_SYSTEM_INTERRUPT_GPIO_DISABLED 0x00
#define VL53L0X_REG_SYSTEM_INTERRUPT_GPIO_LEVEL_LOW 0x01
#define VL53L0X_REG_SYSTEM_INTERRUPT_GPIO_LEVEL_HIGH 0x02
#define VL53L0X_REG_SYSTEM_INTERRUPT_GPIO_OUT_OF_WINDOW 0x03
#define VL53L0X_REG_SYSTEM_INTERRUPT_GPIO_NEW_SAMPLE_READY 0x04
#define VL53L0X_REG_GPIO_HV_MUX_ACTIVE_HIGH 0x0084
#define VL53L0X_REG_SYSTEM_INTERRUPT_CLEAR 0x000B
/* Result registers */
#define VL53L0X_REG_RESULT_INTERRUPT_STATUS 0x0013
#define VL53L0X_REG_RESULT_RANGE_STATUS 0x0014
#define VL53L0X_REG_RESULT_CORE_PAGE 1
#define VL53L0X_REG_RESULT_CORE_AMBIENT_WINDOW_EVENTS_RTN 0x00BC
#define VL53L0X_REG_RESULT_CORE_RANGING_TOTAL_EVENTS_RTN 0x00C0
#define VL53L0X_REG_RESULT_CORE_AMBIENT_WINDOW_EVENTS_REF 0x00D0
#define VL53L0X_REG_RESULT_CORE_RANGING_TOTAL_EVENTS_REF 0x00D4
#define VL53L0X_REG_RESULT_PEAK_SIGNAL_RATE_REF 0x00B6
/* Algo register */
#define VL53L0X_REG_ALGO_PART_TO_PART_RANGE_OFFSET_MM 0x0028
#define VL53L0X_REG_I2C_SLAVE_DEVICE_ADDRESS 0x008a
/* Check Limit registers */
#define VL53L0X_REG_MSRC_CONFIG_CONTROL 0x0060
#define VL53L0X_REG_PRE_RANGE_CONFIG_MIN_SNR 0X0027
#define VL53L0X_REG_PRE_RANGE_CONFIG_VALID_PHASE_LOW 0x0056
#define VL53L0X_REG_PRE_RANGE_CONFIG_VALID_PHASE_HIGH 0x0057
#define VL53L0X_REG_PRE_RANGE_MIN_COUNT_RATE_RTN_LIMIT 0x0064
#define VL53L0X_REG_FINAL_RANGE_CONFIG_MIN_SNR 0X0067
#define VL53L0X_REG_FINAL_RANGE_CONFIG_VALID_PHASE_LOW 0x0047
#define VL53L0X_REG_FINAL_RANGE_CONFIG_VALID_PHASE_HIGH 0x0048
#define VL53L0X_REG_FINAL_RANGE_CONFIG_MIN_COUNT_RATE_RTN_LIMIT 0x0044
#define VL53L0X_REG_PRE_RANGE_CONFIG_SIGMA_THRESH_HI 0X0061
#define VL53L0X_REG_PRE_RANGE_CONFIG_SIGMA_THRESH_LO 0X0062
/* PRE RANGE registers */
#define VL53L0X_REG_PRE_RANGE_CONFIG_VCSEL_PERIOD 0x0050
#define VL53L0X_REG_PRE_RANGE_CONFIG_TIMEOUT_MACROP_HI 0x0051
#define VL53L0X_REG_PRE_RANGE_CONFIG_TIMEOUT_MACROP_LO 0x0052
#define VL53L0X_REG_SYSTEM_HISTOGRAM_BIN 0x0081
#define VL53L0X_REG_HISTOGRAM_CONFIG_INITIAL_PHASE_SELECT 0x0033
#define VL53L0X_REG_HISTOGRAM_CONFIG_READOUT_CTRL 0x0055
#define VL53L0X_REG_FINAL_RANGE_CONFIG_VCSEL_PERIOD 0x0070
#define VL53L0X_REG_FINAL_RANGE_CONFIG_TIMEOUT_MACROP_HI 0x0071
#define VL53L0X_REG_FINAL_RANGE_CONFIG_TIMEOUT_MACROP_LO 0x0072
#define VL53L0X_REG_CROSSTALK_COMPENSATION_PEAK_RATE_MCPS 0x0020
#define VL53L0X_REG_MSRC_CONFIG_TIMEOUT_MACROP 0x0046
#define VL53L0X_REG_SOFT_RESET_GO2_SOFT_RESET_N 0x00BF
#define VL53L0X_WHO_AM_I 0x00C0 // should be 0x40
#define VL53L0X_REG_IDENTIFICATION_MODEL_ID 0x00C0
#define VL53L0X_REG_IDENTIFICATION_REVISION_ID 0x00C2
#define VL53L0X_REG_OSC_CALIBRATE_VAL 0x00F8
#define VL53L0X_SIGMA_ESTIMATE_MAX_VALUE 65535
/* equivalent to a range sigma of 655.35mm */
#define VL53L0X_REG_GLOBAL_CONFIG_VCSEL_WIDTH 0x032
#define VL53L0X_REG_GLOBAL_CONFIG_SPAD_ENABLES_REF_0 0x0B0
#define VL53L0X_REG_GLOBAL_CONFIG_SPAD_ENABLES_REF_1 0x0B1
#define VL53L0X_REG_GLOBAL_CONFIG_SPAD_ENABLES_REF_2 0x0B2
#define VL53L0X_REG_GLOBAL_CONFIG_SPAD_ENABLES_REF_3 0x0B3
#define VL53L0X_REG_GLOBAL_CONFIG_SPAD_ENABLES_REF_4 0x0B4
#define VL53L0X_REG_GLOBAL_CONFIG_SPAD_ENABLES_REF_5 0x0B5
#define VL53L0X_REG_GLOBAL_CONFIG_REF_EN_START_SELECT 0xB6
#define VL53L0X_REG_DYNAMIC_SPAD_NUM_REQUESTED_REF_SPAD 0x4E /* 0x14E */
#define VL53L0X_REG_DYNAMIC_SPAD_REF_EN_START_OFFSET 0x4F /* 0x14F */
#define VL53L0X_REG_POWER_MANAGEMENT_GO1_POWER_FORCE 0x80
#define VL53L0X_POWERMODE_STANDBY 0x00 //set power mode to standby level 1
#define VL53L0X_POWERMODE_IDLE 0x01 //set power mode to idle level 1
* Speed of light in um per 1E-10 Seconds
#define VL53L0X_SPEED_OF_LIGHT_IN_AIR 2997
#define VL53L0X_REG_VHV_CONFIG_PAD_SCL_SDA__EXTSUP_HV 0x0089
#define VL53L0X_REG_ALGO_PHASECAL_LIM 0x0030 /* 0x130 */
#define VL53L0X_REG_ALGO_PHASECAL_CONFIG_TIMEOUT 0x0030
// Using the VL53L0X breakout board/Teensy 3.1 Add-On Shield, device address is 0x29
#define VL53L0X_ADDRESS 0x29 // Device address of VL53L0X
// Pin definitions
int myLed = D7;
int intPin = D2;
volatile bool newData = false;
uint8_t rangeData[14];
uint8_t rawData[4] = {0, 0, 0, 0};
uint32_t lastUpdate = 0, Now = 0; // used to calculate sample data rate
// Low and High thresholds in mm
uint16_t ThresholdLow = 350;
uint16_t ThresholdHigh = 150;
#define verboseMode true
//Wire.setSpeed(CLOCK_SPEED_400KHZ);
Wire.begin();
//delay(4000);
Serial.begin(115200);
while(!Serial.available()) Particle.process();
// Set up the led indicator
pinMode(myLed, OUTPUT);
digitalWrite(myLed, LOW);
pinMode(intPin, INPUT);
byte HVI2C = readByte(VL53L0X_ADDRESS, VL53L0X_REG_VHV_CONFIG_PAD_SCL_SDA__EXTSUP_HV);
writeByte(VL53L0X_ADDRESS, VL53L0X_REG_VHV_CONFIG_PAD_SCL_SDA__EXTSUP_HV, HVI2C | 0x01); // set I2C HIGH to 2.8 V
I2Cscan();
delay(1000);
// Read the WHO_AM_I register, this is a good test of communication
Serial.println("VL53L0X proximity sensor...");
byte c = readByte(VL53L0X_ADDRESS, VL53L0X_WHO_AM_I); // Read WHO_AM_I register for VL53L0X
Serial.print("VL53L0X "); Serial.print("I AM "); Serial.print(c, HEX); Serial.print(" I should be "); Serial.println(0xEE, HEX);
// Get info about the specific device
byte revID = readByte(VL53L0X_ADDRESS, VL53L0X_REG_IDENTIFICATION_REVISION_ID); // Read Revision ID register for VL53L0X
Serial.print("VL53L0X revision ID 0X"); Serial.println(revID, HEX);
delay(1000);
if (c == 0xEE) // VL53L0X WHO_AM_I should always be 0xEE
Serial.println("VL53L0X is online...");
writeByte(VL53L0X_ADDRESS, VL53L0X_REG_SOFT_RESET_GO2_SOFT_RESET_N, 0x01); // reset device
delay(100);
if ((HVI2C & ~0xFE) == 0x00) Serial.println("I2C IO voltage is 1V8");
if ((HVI2C & ~0xFE) == 0x01) Serial.println("I2C IO voltage is 2V8");
// "Set I2C standard mode"
writeByte(VL53L0X_ADDRESS, 0x88, 0x00);
writeByte(VL53L0X_ADDRESS, 0x80, 0x01);
writeByte(VL53L0X_ADDRESS, 0xFF, 0x01);
writeByte(VL53L0X_ADDRESS, 0x00, 0x00);
uint8_t stop_variable = readByte(VL53L0X_ADDRESS, 0x91);
writeByte(VL53L0X_ADDRESS, 0x00, 0x01);
writeByte(VL53L0X_ADDRESS, 0xFF, 0x00);
writeByte(VL53L0X_ADDRESS, 0x80, 0x00);
// Taken from Pololu Arduino version of ST's API code
uint8_t spad_count;
bool spad_type_is_aperture;
getSpadInfo(&spad_count, &spad_type_is_aperture);
// if (!getSpadInfo(&spad_count, &spad_type_is_aperture)) { return false; }
// The SPAD map (RefGoodSpadMap) is read by VL53L0X_get_info_from_device() in
// the API, but the same data seems to be more easily readable from
// GLOBAL_CONFIG_SPAD_ENABLES_REF_0 through _6, so read it from there
uint8_t ref_spad_map[6];
readBytes(VL53L0X_ADDRESS, VL53L0X_REG_GLOBAL_CONFIG_SPAD_ENABLES_REF_0, 6, ref_spad_map);
// -- VL53L0X_set_reference_spads() begin (assume NVM values are valid)
writeByte(VL53L0X_ADDRESS, VL53L0X_REG_DYNAMIC_SPAD_REF_EN_START_OFFSET, 0x00);
writeByte(VL53L0X_ADDRESS, VL53L0X_REG_DYNAMIC_SPAD_NUM_REQUESTED_REF_SPAD, 0x2C);
writeByte(VL53L0X_ADDRESS, VL53L0X_REG_GLOBAL_CONFIG_REF_EN_START_SELECT, 0xB4);
uint8_t first_spad_to_enable = spad_type_is_aperture ? 12 : 0; // 12 is the first aperture spad
uint8_t spads_enabled = 0;
for (uint8_t i = 0; i < 48; i++)
if (i < first_spad_to_enable || spads_enabled == spad_count)
// This bit is lower than the first one that should be enabled, or
// (reference_spad_count) bits have already been enabled, so zero this bit
ref_spad_map[i / 8] &= ~(1 << (i % 8));
else if ((ref_spad_map[i / 8] >> (i % 8)) & 0x1)
spads_enabled++;
writeByte(VL53L0X_ADDRESS, VL53L0X_REG_GLOBAL_CONFIG_SPAD_ENABLES_REF_0, ref_spad_map[0]);
writeByte(VL53L0X_ADDRESS, VL53L0X_REG_GLOBAL_CONFIG_SPAD_ENABLES_REF_1, ref_spad_map[1]);
writeByte(VL53L0X_ADDRESS, VL53L0X_REG_GLOBAL_CONFIG_SPAD_ENABLES_REF_2, ref_spad_map[2]);
writeByte(VL53L0X_ADDRESS, VL53L0X_REG_GLOBAL_CONFIG_SPAD_ENABLES_REF_3, ref_spad_map[3]);
writeByte(VL53L0X_ADDRESS, VL53L0X_REG_GLOBAL_CONFIG_SPAD_ENABLES_REF_4, ref_spad_map[4]);
writeByte(VL53L0X_ADDRESS, VL53L0X_REG_GLOBAL_CONFIG_SPAD_ENABLES_REF_5, ref_spad_map[5]);
// -- VL53L0X_set_reference_spads() end
// -- VL53L0X_load_tuning_settings() begin
// DefaultTuningSettings from vl53l0x_tuning.h
writeByte(VL53L0X_ADDRESS, 0x09, 0x00);
writeByte(VL53L0X_ADDRESS, 0x10, 0x00);
writeByte(VL53L0X_ADDRESS, 0x11, 0x00);
writeByte(VL53L0X_ADDRESS, 0x24, 0x01);
writeByte(VL53L0X_ADDRESS, 0x25, 0xFF);
writeByte(VL53L0X_ADDRESS, 0x75, 0x00);
writeByte(VL53L0X_ADDRESS, 0x4E, 0x2C);
writeByte(VL53L0X_ADDRESS, 0x48, 0x00);
writeByte(VL53L0X_ADDRESS, 0x30, 0x20);
writeByte(VL53L0X_ADDRESS, 0x30, 0x09);
writeByte(VL53L0X_ADDRESS, 0x54, 0x00);
writeByte(VL53L0X_ADDRESS, 0x31, 0x04);
writeByte(VL53L0X_ADDRESS, 0x32, 0x03);
writeByte(VL53L0X_ADDRESS, 0x40, 0x83);
writeByte(VL53L0X_ADDRESS, 0x46, 0x25);
writeByte(VL53L0X_ADDRESS, 0x60, 0x00);
writeByte(VL53L0X_ADDRESS, 0x27, 0x00);
writeByte(VL53L0X_ADDRESS, 0x50, 0x06);
writeByte(VL53L0X_ADDRESS, 0x51, 0x00);
writeByte(VL53L0X_ADDRESS, 0x52, 0x96);
writeByte(VL53L0X_ADDRESS, 0x56, 0x08);
writeByte(VL53L0X_ADDRESS, 0x57, 0x30);
writeByte(VL53L0X_ADDRESS, 0x61, 0x00);
writeByte(VL53L0X_ADDRESS, 0x62, 0x00);
writeByte(VL53L0X_ADDRESS, 0x64, 0x00);
writeByte(VL53L0X_ADDRESS, 0x65, 0x00);
writeByte(VL53L0X_ADDRESS, 0x66, 0xA0);
writeByte(VL53L0X_ADDRESS, 0x22, 0x32);
writeByte(VL53L0X_ADDRESS, 0x47, 0x14);
writeByte(VL53L0X_ADDRESS, 0x49, 0xFF);
writeByte(VL53L0X_ADDRESS, 0x4A, 0x00);
writeByte(VL53L0X_ADDRESS, 0x7A, 0x0A);
writeByte(VL53L0X_ADDRESS, 0x7B, 0x00);
writeByte(VL53L0X_ADDRESS, 0x78, 0x21);
writeByte(VL53L0X_ADDRESS, 0x23, 0x34);
writeByte(VL53L0X_ADDRESS, 0x42, 0x00);
writeByte(VL53L0X_ADDRESS, 0x44, 0xFF);
writeByte(VL53L0X_ADDRESS, 0x45, 0x26);
writeByte(VL53L0X_ADDRESS, 0x46, 0x05);
writeByte(VL53L0X_ADDRESS, 0x40, 0x40);
writeByte(VL53L0X_ADDRESS, 0x0E, 0x06);
writeByte(VL53L0X_ADDRESS, 0x20, 0x1A);
writeByte(VL53L0X_ADDRESS, 0x43, 0x40);
writeByte(VL53L0X_ADDRESS, 0x34, 0x03);
writeByte(VL53L0X_ADDRESS, 0x35, 0x44);
writeByte(VL53L0X_ADDRESS, 0x4B, 0x09);
writeByte(VL53L0X_ADDRESS, 0x4C, 0x05);
writeByte(VL53L0X_ADDRESS, 0x4D, 0x04);
writeByte(VL53L0X_ADDRESS, 0x44, 0x00);
writeByte(VL53L0X_ADDRESS, 0x45, 0x20);
writeByte(VL53L0X_ADDRESS, 0x47, 0x08);
writeByte(VL53L0X_ADDRESS, 0x48, 0x28);
writeByte(VL53L0X_ADDRESS, 0x67, 0x00);
writeByte(VL53L0X_ADDRESS, 0x70, 0x04);
writeByte(VL53L0X_ADDRESS, 0x71, 0x01);
writeByte(VL53L0X_ADDRESS, 0x72, 0xFE);
writeByte(VL53L0X_ADDRESS, 0x76, 0x00);
writeByte(VL53L0X_ADDRESS, 0x77, 0x00);
writeByte(VL53L0X_ADDRESS, 0x0D, 0x01);
writeByte(VL53L0X_ADDRESS, 0x01, 0xF8);
writeByte(VL53L0X_ADDRESS, 0x8E, 0x01);
// -- VL53L0X_load_tuning_settings() end
// Configure GPIO1 for interrupt, active LOW
byte actHIGH = readByte(VL53L0X_ADDRESS, VL53L0X_REG_GPIO_HV_MUX_ACTIVE_HIGH);
//writeByte(VL53L0X_ADDRESS, VL53L0X_REG_SYSTEM_INTERRUPT_CONFIG_GPIO, 0x04); // enable data ready interrupt
/* Need to divide by 2 because the FW will apply a x2 */
writeWord(VL53L0X_ADDRESS, VL53L0X_REG_SYSTEM_THRESH_LOW, ThresholdLow>>1);
writeWord(VL53L0X_ADDRESS, VL53L0X_REG_SYSTEM_THRESH_HIGH, ThresholdHigh>>1);
/* Set GPIO pin interrupt mode:
THRESHOLD_CROSSED_LOW = 0x01
THRESHOLD_CROSSED_HIGH = 0x02
THRESHOLD_CROSSED_OUT = 0x03
NEW_MEASURE_READY = 0x04
writeByte(VL53L0X_ADDRESS, VL53L0X_REG_SYSTEM_INTERRUPT_CONFIG_GPIO, 0x02); // enable data ready interrupt
writeByte(VL53L0X_ADDRESS, VL53L0X_REG_GPIO_HV_MUX_ACTIVE_HIGH, actHIGH & ~0x10); // GPIO1 interrupt active LOW
writeByte(VL53L0X_ADDRESS, VL53L0X_REG_SYSTEM_INTERRUPT_CLEAR, 0x01); // clear interrupt
// Get some basic information about the sensor
byte val1 = readByte(VL53L0X_ADDRESS, VL53L0X_REG_PRE_RANGE_CONFIG_VCSEL_PERIOD);
Serial.print("PRE_RANGE_CONFIG_VCSEL_PERIOD="); Serial.println(val1);
Serial.print(" decode: "); Serial.println(VL53L0X_decode_vcsel_period(val1));
val1 = readByte(VL53L0X_ADDRESS, VL53L0X_REG_FINAL_RANGE_CONFIG_VCSEL_PERIOD);
Serial.print("FINAL_RANGE_CONFIG_VCSEL_PERIOD="); Serial.println(val1);
readBytes(VL53L0X_ADDRESS, VL53L0X_REG_SYSTEM_INTERMEASUREMENT_PERIOD, 4, &rawData[0]);
uint32_t IMPeriod = (((uint32_t) rawData[0]) << 24 | ((uint32_t) rawData[1]) << 16 | ((uint32_t) rawData[2]) << 8 | rawData[3]);
Serial.print(" System Intermeasurement period = "); Serial.print(IMPeriod); Serial.println(" ms");
writeByte(VL53L0X_ADDRESS, VL53L0X_REG_SYSRANGE_START, 0x02); // continuous mode and arm next shot
attachInterrupt(intPin, myinthandler, FALLING); // define interrupt for GPI01 pin output of VL53L0X
else
Serial.print("Could not connect to VL53L0X: 0x");
Serial.println(c, HEX);
while(1) ; // Loop forever if communication doesn't happen
// byte intStatus = readByte(VL53L0X_ADDRESS, VL53L0X_REG_RESULT_RANGE_STATUS);// Poll for data ready
// if(intStatus & 0x01) // poll for data ready
if(newData) // wait for data ready interrupt
newData = false;
Now = micros();
Serial.print("data rate = "); Serial.print(1000000./(Now - lastUpdate)); Serial.println(" Hz");
readBytes(VL53L0X_ADDRESS, VL53L0X_REG_RESULT_RANGE_STATUS, 14, &rangeData[0]); // continuous ranging
Serial.print("byte 1 = "); Serial.println(rangeData[0]);
Serial.print("byte 2 = "); Serial.println(rangeData[1]);
Serial.print("byte 3 = "); Serial.println(rangeData[2]);
Serial.print("byte 4 = "); Serial.println(rangeData[3]);
Serial.print("byte 5 = "); Serial.println(rangeData[4]);
Serial.print("byte 6 = "); Serial.println(rangeData[5]);
Serial.print("byte 7 = "); Serial.println(rangeData[6]);
Serial.print("byte 8 = "); Serial.println(rangeData[7]);
Serial.print("byte 9 = "); Serial.println(rangeData[8]);
Serial.print("byte 10 = "); Serial.println(rangeData[9]);
Serial.print("byte 11 = "); Serial.println(rangeData[10]);
Serial.print("byte 12 = "); Serial.println(rangeData[11]);
Serial.print("byte 13 = "); Serial.println(rangeData[12]);
Serial.print("byte 14 = "); Serial.println(rangeData[13]);
Serial.println(" ");
byte devError = (rangeData[0] & 0x78) >> 3; // Check for errors
if(devError == 0) Serial.println("Data OK!");// No device error
if(devError == 0x01) Serial.println("VCSEL CONTINUITY TEST FAILURE!");
if(devError == 0x02) Serial.println("VCSEL WATCHDOG TEST FAILURE!");
if(devError == 0x03) Serial.println("NO VHV VALUE FOUND!");
if(devError == 0x04) Serial.println("MSRC NO TARGET!");
if(devError == 0x05) Serial.println("SNR CHECK!");
if(devError == 0x06) Serial.println("RANGE PHASE CHECK!");
if(devError == 0x07) Serial.println("SIGMA THRESHOLD CHECK!");
if(devError == 0x08) Serial.println("TCC!");
if(devError == 0x09) Serial.println("PHASE CONSISTENCY!");
if(devError == 0x0A) Serial.println("MIN CLIP!");
if(devError == 0x0B) Serial.println("RANGE COMPLETE!");
if(devError == 0x0C) Serial.println("ALGO UNDERFLOW!");
if(devError == 0x0D) Serial.println("ALGO OVERFLOW!");
if(devError == 0x0E) Serial.println("RANGE IGNORE THRESHOLD!");
Serial.print("Effective SPAD Return Count = "); Serial.println( ((float) (rangeData[2]) + (float)rangeData[3]/255.), 2); // 8.8 format
Serial.print("Signal Rate = "); Serial.print( (uint16_t) ((uint16_t) rangeData[6] << 8) | rangeData[7]); Serial.println(" mega counts per second");
Serial.print("Ambient Rate = "); Serial.print( (uint16_t) ((uint16_t) rangeData[8] << 8) | rangeData[9]); Serial.println(" mega counts per second");
Serial.print("Distance = "); Serial.print( (uint16_t) ((uint16_t) rangeData[10] << 8) | rangeData[11]); Serial.println(" mm");
lastUpdate = Now;
digitalWrite(myLed, !digitalRead(myLed));
//====== Set of useful function to access acceleration. gyroscope, magnetometer, and temperature data
void myinthandler()
newData = true;
// Get reference SPAD (single photon avalanche diode) count and type
// based on VL53L0X_get_info_from_device(),
// but only gets reference SPAD count and type
bool getSpadInfo(uint8_t * count, bool * type_is_aperture)
uint8_t tmp;
writeByte(VL53L0X_ADDRESS, 0xFF, 0x06);
writeByte(VL53L0X_ADDRESS, 0x83, readByte(VL53L0X_ADDRESS, 0x83) | 0x04);
writeByte(VL53L0X_ADDRESS, 0xFF, 0x07);
writeByte(VL53L0X_ADDRESS, 0x81, 0x01);
writeByte(VL53L0X_ADDRESS, 0x94, 0x6b);
writeByte(VL53L0X_ADDRESS, 0x83, 0x00);
startTimeout();
while (readByte(VL53L0X_ADDRESS, 0x83) == 0x00)
if (checkTimeoutExpired()) { return false; }
writeByte(VL53L0X_ADDRESS, 0x83, 0x01);
tmp = readByte(VL53L0X_ADDRESS, 0x92);
*count = tmp & 0x7f;
*type_is_aperture = (tmp >> 7) & 0x01;
writeByte(VL53L0X_ADDRESS, 0x81, 0x00);
writeByte(VL53L0X_ADDRESS, 0x83, readByte(VL53L0X_ADDRESS, 0x83 & ~0x04));
return true;
uint16_t VL53L0X_decode_vcsel_period(short vcsel_period_reg) {
// Converts the encoded VCSEL period register value into the real
// period in PLL clocks
uint16_t vcsel_period_pclks = (vcsel_period_reg + 1) << 1;
return vcsel_period_pclks;
// I2C scan function
void I2Cscan()
// scan for i2c devices
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknow error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
else
Serial.println("done\n");
// I2C read/write functions for the VL53L0X sensor
// VL53L0X has 16-bit register addresses, so the MSB of the register is sent first, then the LSB
void writeByte(uint8_t address, uint16_t subAddress, uint8_t data)
Wire.beginTransmission(address); // Initialize the Tx buffer
// Wire.write((subAddress >> 8) & 0xFF); // Put MSB of 16-bit slave register address in Tx buffer
Wire.write(subAddress & 0xFF); // Put LSB of 16-bit slave register address in Tx buffer
Wire.write(data); // Put data in Tx buffer
Wire.endTransmission(); // Send the Tx buffer
void writeWord(uint8_t address, uint16_t subAddress, uint16_t data) {
Wire.write((uint8_t)data>>8 & 0xFF);
Wire.write((uint8_t)data>>0 & 0xFF);
uint8_t readByte(uint8_t address, uint16_t subAddress)
uint8_t data; // `data` will store the register data
Wire.endTransmission(I2C_NOSTOP); // Send the Tx buffer, but send a restart to keep connection alive
// Wire.endTransmission(false); // Send the Tx buffer, but send a restart to keep connection alive
// Wire.requestFrom(address, 1); // Read one byte from slave register address
Wire.requestFrom(address, (size_t) 1); // Read one byte from slave register address
data = Wire.read(); // Fill Rx buffer with result
return data; // Return data read from slave register
void readBytes(uint8_t address, uint16_t subAddress, uint8_t count, uint8_t * dest)
uint8_t i = 0;
// Wire.requestFrom(address, count); // Read bytes from slave register address
Wire.requestFrom(address, (size_t) count); // Read bytes from slave register address
while (Wire.available()) {
delay(1);
dest[i++] = Wire.read(); } // Put read results in the Rx buffer
One thing to note - based on the VL53L0X API docs 6.8 - is that the max threshold for single ranging is 254mm. Longer ranges can only be signalled via interrupts in continous or timed continous mode.
@Peekay123 Great Progress You just made this sensor much more useful!
Does Scruff’s link explain why the high end point ends up being 250mm?
I see the interrup being used like in a hallway where your getting a constant reading for the sensor to the other hallway wall and then you just want to trigger the interrupt if that distance decreases as somebody walks past.
Sounds like the Crossed High would work if we can get that max distance to work out to 1650mm which is what your goin to need in house hallway.
Here is some more code I came across for this sensor if it’s of any help as a communication example:
@RWB, @ScruffR’s comments just add to the mystery though it makes sense. The sampling mode in the code is set by:
I’ll have to dig into that setting to understand more.
I invited Kris Winer over here in case he wants to pitch in and see if we can combine brain power and efforts to get these interrupt functions knocked out
Thanks for the progress and efforts! Nobody else has figured this out yet.
I posted several sketches using the Pololu library where the interrupt works just fine, either using the Teensy or STM32L4. It’s here:
Not sure why this is such a problem, other than not havingaccess to the register map and all!
But the Pololu library works well and I recommned everyone stop trying to reinvent the wheel and just use it. I do.
Kris
@RWB, setting a value of 0x02 is "VL53L0X_REG_SYSRANGE_MODE_BACKTOBACK" or continuous ranging mode so not sure why the 254mm range would apply. Nonetheless, trying different values for the interrupt and the low/high thresholds is not working as expected.
