curl -G https://api.particle.io/v1/devices/$DEVICE$/heat -d access_token=$ACCESS_TOKEN$
response I get is:
"error": "Timed out."
exposed variable heat is from a very simple code.
Spark.variable("heat", &heat, DOUBLE);
worked the first time, then stopped working.
