I’m in the process of upgrading our System Firmware to the latest (or at least a newer) version.
Starting from 0.5.3, I’ve ported our app to 0.6.4 and updated our tests.
Now I’m attempting to port us to 0.7.0. Tests are being run on an electron.
However it looks like 0.7.0 breaks USB Serial on Linux (Raspbian/Debian 9 and Ubuntu 18.04).
The serial port is registered with the system (everything looks good in dmesg, detected as a ttyACM device) however I never get an TX/RX data on the serial port.
Normally we build the System Firmware ourselves, but I’ve confirmed this problem also exists with the 0.7.0 binaries taken from GitHub releases (for 0.7.0).
I’ve created a sample app that I can use to repro this issue on a Raspberry Pi, and my development system.
#include <application.h>
unsigned long timer;
Serial.begin();
Serial.println("Setup");
timer = millis();
if ((millis() - timer) > 1000)
Serial.printf("TIME: %x\r\n", millis());
timer = millis();
Is this a known problem with 0.7.0? What steps can I take to further explore this issue?
