Using Relay with Photon for controlling Lamp
I need to control a standard lamp using Photon.
I have the code, I dont know much about H/W so I’m following this tutorial to wire up the Relay:
I’m using this Relay.
However, the tutorial is for Arduino Uno.
How do I give the 5V to Relay’s VCC? Do I use Photon’s VIN?
Should I use Shield Shield? How should I use Shield Shield?
There are some threads about relays on this forum already dealing with your questions.
Have a search for relay 5V, you’ll be surprised :wink:
@dushyantbangal, you CAN power the relays with Photon’s VIN and GND pins assuming you have a good quality USB power supply (1 Amp ideally). Since the relay board uses opto-isolators, you can connect the IN1/IN2 lines directly to Photon Dx pins. :smile:
Just so it's been said: mains can and will kill you, please be careful. If you're uncertain about something, don't take the risk, it's not worth it. If in doubt, contact a professional electrician.
Ohh I do plan to stay faar away when i switch it on :smiley:
here’s a simple and relatively safe way:
@dushyantbangal, here is an even SAFER way to do it:
http://www.powerswitchtail.com/Pages/default.aspx
:wink:
It works! My main doubt was about the VIN => VCC of 5V, which was solved
Btw, I used an adapter with output of 5V and 2.0A
Thank you everyone :smile:
:frowning: this link no longer works
The main page is often a good idea: http://www.powerswitchtail.com
