Using Photon in a classroom setup
We are planning to teach a short (3hrs) IoT class to middle school girls using the photon, breadboard and LED (about our classes www.orcsgirls.org). We could use some advice or lessons learned about setting this up in a class room. We have 20 Photons, one per student. Here are some questions
Accounts: One per participant or one for everyone or using a Project somehow. Since not everyone has a phone and we cannot easily install software in the classroom we use, the Photons would need to be claimed by the right account before class. Less work = happier teachers :slight_smile:
WiFi: The WiFi has a splash screen to accept rules and conditions, so I am not sure how the Photon can connect. Alternatively we have a router and a 4G hotspot. Any experience if that is sufficient bandwidth for 20 girls to communicate and flash the Photons?
Any other pitfalls someone running classes/hack-a-thons worth knowing about?
Thank you so much for any help.
Thomas
You can set up everything ahead of time with a single shared account. For a short duration program like that, it certainly would speed up the setup process. I’ve included some tips below that are more applicable to classes spanning multiple sessions or a full day.
If your network allows Wi-Fi to Wi-Fi access points, those often work in hotels with a captive portal. Managed networks like school networks might block access, however, so that might not work. The firewall may also block the cloud connection so a hotspot may be necessary.
For the Photon, the binaries are small, typically under 10K for small blink LED type programs, so the amount of data should not be a problem, as long as the hotspot supports a sufficient number of users.
Particle Photon tips for classrooms
Some useful tips for using the Particle Photon in classrooms, hackathons, etc.
Option 1: Self-configuration
With the self-configuration option, students:
  • Create their own Particle accounts, either with school or personal email.
  • Set up Wi-Fi and claim the Photon to their account with their personal phones.
This method is allows factory-fresh Photons to be unboxed and used immediately, however there are some caveats:
  • Some phones have difficulties setting up a Photon (often Android phones, but sometimes iPhones as well).
  • This process is hard to debug since there isn’t much feedback if something goes wrong.
  • Wi-Fi based configuration always uses Wi-Fi channel 1 when in listening mode (blinking blue). With a large number of Photons simultaneously using the same Wi-Fi channel interference can result. It may be helpful to stagger turning on the Photons.
Setting up an instructor station
It’s a good idea to set up an instructor station that has the Particle CLI installed. This can be used to help out students who don’t have a phone or whose phone does not work, and also troubleshoot some more difficult issues.
If the student is unable to claim the device, these commands usually solve the problem:
particle identify
particle serial wifi
The particle identify command prints out the device ID of the Photon. This is important because it will be necessary to for the student to enter this to claim the device.
The particle serial wifi command sets up the Wi-Fi network but does not claim the device, allowing the student to claim the device on their own account.
If the Photon gets all the way to breathing cyan, then the student can log into https://build.particle.io and uses the Devices icon (circle with 4 lines) and uses the Add Device option, entering the device ID for the Photon.
Option 2: Preconfiguring Wi-Fi
Another option is to set up the Photon Wi-Fi on each Photon ahead of time. This simplifies setup for the student:
  • Create their own Particle accounts, either with school or personal email, typically from a web browser.
  • Claim the device to their Particle account using Particle Build (Web IDE) or Particle Dev (Atom IDE), whatever you are using for programming.
  • No phone is needed for setup.
Student process
The student:
  • Receives a Photon with the Wi-Fi configured, so plugging it in should go through the normal sequence of white, blinking green, blinking cyan (light blue), fast blinking cyan, and breathing cyan.
  • Also receives the device ID for the Photon, a 24-character combination of numbers and the letters a-f. Note that the letters should always be entered in lower case.
  • Goes to https://build.particle.io and logs in or creates an Particle account.
  • Uses the Devices icon (circle with 4 lines) and uses the Add Device option, entering the device ID for the Photon.
Pre-configuration process
The easiest way to pre-configure Wi-Fi is using the Particle CLI. With the Photon in listening mode (blinking blue), use the commands:
particle identify
The particle serial wifi command sets up the Wi-Fi network but does not claim the device, which is perfect for this application.
Debugging tips
The normal sequence of the status LED is:
  • White
  • Blinking green
  • Blinking cyan
  • Fast blinking cyan
  • Breathing cyan
The point where it stops can be helpful in determining what went wrong.
Stops at blinking green
If some Photons cannot get past this state:
  • If your network has run out of available IP addresses in the DHCP address pool, the Photon will stop at blinking green. The network administrator can usually check this.
  • If your network restricts access to certain devices by Ethernet MAC address, you will need to make sure the affected Photon is allowed. Your network administrator will tell if you if this is necessary. You can find your MAC address using the instructions here. This is not common.
If no Photons can get past this state:
  • If you are using a corporate or school network that uses WPA2 Enterprise, the Photon cannot be used at this time. If you require both a username and a password, or see a mention of 802.1(x), or RADIUS you’re using WPA2 Enterprise.
  • If you are using a network that takes you to a web page where you need to either sign in or agree to terms and service when you first connect, using the Photon directly will be difficult or impossible. This is the case in some hotels and public Wi-Fi networks and is often referred to as Captive Portal.
  • If your Wi-Fi network uses 5 GHz only, instead of the more common 2.4 GHz, the Photon cannot be used. The Wi-Fi radio is only compatible with 2.4 GHz networks.
Blinking cyan or fast blinking cyan
  • This can sometimes indicate a problem with DNS or a Firewall. Using the diagnostic program in the following section will show when this is occurring.
  • Photons running system firmware 0.6.0 and later require working DNS (domain name service) to connect to the cloud. If your DHCP server is returning an invalid DNS server, or the DNS server is not functioning correctly, the Photon may not be able to connect to the cloud.
  • The firewall must allow outbound TCP access to port 5683 (CoAP) on device.spark.io (currently 54.173.1.44 but the address may change) to allow Photons to connect to the cloud.
  • It should also allow outbound https (port 443) to build.particle.io, console.particle.io and api.particle.io for building and using the API.
Fast blinking cyan with red or orange blinks
This sometimes indicates a problem with the server or device keys.
Put the Photon into Listening mode (blinking blue) by holding down SETUP until it blinks blue. Then issue the CLI command:
particle identify
Save the Device ID; you’ll need it later.
Then put the Photon in DFU mode by holding down both the RESET and SETUP buttons, releasing RESET and continuing to hold down SETUP until it blinks yellow and issue the commands below, in order.
particle keys server
particle keys doctor YOUR_DEVICE_ID
Running the cloud debug program
Sometimes it’s not possible to tell what’s going wrong just by monitoring the lights. Flashing this firmware to the device will print out additional debugging information. The log file can be sent to Particle support for further investigation.
https://github.com/rickkas7/photon-clouddebug
Recycling Photons
If you reuse the Photons with another class, it will be necessary to do some work to clean them up. You can save a great deal of effort by requesting that the departing students unclaim the devices from their accounts. It’s possible to recover if they don’t, but it adds several steps to the process.
Complete instructions are here: https://github.com/rickkas7/photonreset.
