Using P1 module | USB port to read log/printf
Dear team,
Could you please advise if I could read LOG/Printf from the USB port (of P1) or I must use UART to read Printf?
Also, I would like to know if the JTAG port on the P1 module works and if I can use a debugger on these JTAG pins to debug my application?
Waiting for your kind feedback, Thanks a lot.
Regards,
Shai
The P1 module itself doesn't have a USB connector but if you have one on your base board it is supported.
The standard C library printf is not supported, however Serial is the USB serial port, and the log handler can be used to write to USB serial.
JTAG/SWD is enabled in the bootloader for code flashing, but by default Particle firmware binaries have it disabled. If you build a debug build in Particle Workbench JTAG/SWD is enabled and you can use the source debugger with gdb and OpenOCD.
@rickkas7 Hello,
Thank you for your fast response, as I understand the LOG handler works via USB.
I found the below guide and if I need further support I'll let you know.
Thanks a lot.
Kind regards,
Shai
